    โš ๏ธ Attention | Having issues with Sketchucation Tools 5? Report Here
    Fillet multiple corners
    12 Posts 5 Posters 932 Views 5 Watching
      pipingguy
      "Double clicking on a face near a vertex connecting two edges automatically creates a fillet with the last used radius, allowing you to quickly fillet multiple corners with the same radius."
      The above was found in 2015 release notes. However, I do not comprehend how to accomplish the work.
      • BoxB Offline
        Use the arc tool to create a radius at a corner. Now move to another corner and double click. It should remove the corner following the same radius.
        • S ShepherdS Offline
          S Shepherd
          A gif is worth a thousand words.
          S
          • ntxdaveN Offline
            ntxdave
            S
            Thanks for sharing.
            Wonder what other gems are hidden in 2015?
            • cottyC Offline
              cotty
              You don't need to delete the edges in the first corner, if you use the purpe inference, the corner is deleted automatically (if you don't want this, you can use the modifier key 'alt').
              my SketchUp gallery
                pipingguy
                Got it! Thanks.
                However - it only works when you're working with a face. It cannot work on mere edges.
                • cottyC Offline
                  cotty
                  @pipingguy said:
                  "Double clicking on a face near a vertex ...
                  Yes ๐Ÿ˜‰
                  my SketchUp gallery
                  • ntxdaveN Offline
                    ntxdave
                    What is the purpe inference?
                    • cottyC Offline
                      cotty
                      Tangent to Edge.
                      my SketchUp gallery
                      • BoxB Offline
                        I've done it slowly so you can see the inference colours.
                        The Aquamarine/Green means the arc is tangent to the edges, but then it changes to Purple/Magenta when the two ends are equidistant from the corner.
                        The two colours are extremely useful in many situations.
                          pipingguy
                          Noticing it will not work on non-rectangular faces such as 3 or 6 sided polygons.
                          • BoxB Offline
                            It does work on non rectangular shapes, as you can see in the animation I did elsewhere.
                            However Polygons are a different beast as they are welded edges so it doesn't see the corners. A quick explode of the curve and the sides become different edges allowing the double click to work.
                            http://i155.photobucket.com/albums/s296/storeben/SU/Three Edges.gif
                            http://i155.photobucket.com/albums/s296/storeben/SU/Poly.gif
