    Dimensioning problem?
    3 Posts 3 Posters 1.7k Views 3 Watching
      tomot
      I don't normally get involved in 1/16" accuracy issues, however in this particular instance it results were aggravating.
      I subdivided a 12" x 12" square into random rectangular shapes, the used offset of 1/16" to create spaces such that I get an 1/8" grout line between each of the rectangular shapes.
      I assumed by typing 1/16" into the VBC I would get a consistent 1/16" offset.
      What I ended up with visually is not 1/16" space, even though dimensioned it shows 1/16" ?
      I'm scratching my head!
      [my plugins](http://thingsvirtual.blogspot.ca/)
      tomot
        I would agree with Box. The dimensions are surely rounded due to the coarse precision setting. I would suggest you set Precision to 1/64" to see more accurate dimensions of what you've created.
        • BoxB Offline
          Change the precision setting to 1/32 and it should readjust.
