    Xml anyone?
    16 Posts 7 Posters 1.8k Views 7 Watching
    • Chris FullmerC Offline
      HeyHey!, I got it to work. I found a pretty clean example from my Ruby book. SO I'll finish my own example, please correct it if its wrong or is missing important things. Thanks!
      def write_file my_text = "Write this line of text to the file" save_path = UI.savepanel "Save File", "", "SU_text.xml" myfile = File.new( save_path, "w" ) myfile.puts my_text myfile.close end
        todd burch
        That'll work.
          You could squeeze in a myfile.flush just before myfile.close to free up the buffer... BUT it's just a nicety for the sort of file work we are likely to do here - I often don't!
          It is very important to 'close' the file at some point when you are finished writing etc... otherwise it stays locked and is then no longer editable/openable until Sketchup closes. My OBJexporter opens the OBJ file and writes to it, using various iterative methods and sub-methods [@file] and when it's finally done it 'closes' it... 😉
            You can open a file for read/write using a block so it's automatically closed when the block is done. I think it even closes the files if you should throw an error.
              todd burch
              Here's the way to process data in your file following the END directive using the DATA constant.
              DATA.each('\n') {|t| puts t }
              puts "....done." ;
              __END__
              Programmers
              Todd Texas Homely
              Chris California Handsome
              • Dan RathbunD Offline
                Dan Rathbun
                @chris fullmer said:
                Anyone care to help whip up a few lines of code as an example of how one would write a simple string to a file?
                Here's an example of a utility script (it won't be disto'd, just creates the text file that will be distro'd. The plugin will use the resultant text file.)
                In this example the String I am writing is a hash string. The plugin will read the hashstring file into a String reference, then eval it back into a Hash object, which is then used by a UI.inputbox to choose the desired font properties. (I posted a pic of the actual inputbox in the beta forum, if interested,... but basically the fontnames get loaded into a dropdown edit control.)
                <span class="syntaxdefault"></span><span class="syntaxcomment"># by Dan Rathbun ; 2011-02-28<br /></span><span class="syntaxdefault">module Dan<br />  module Utility<br /><br />  font_hash </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">%</span><span class="syntaxdefault">q</span><span class="syntaxkeyword">[</span><span class="syntaxcomment">#<br /># Font Hash to use for RubyConsole Toolbar<br />#<br /># To add a preferred font, insert a hash item below where;<br /># the key is the recognized fontname, and<br /># the value is the font filename. See; "Windows/Fonts" folder.<br />#<br /># The list will be alpha sorted after loading, and any fonts<br /># whoose filename does not exist in the "Windows/Fonts" folder,<br /># will be removed from the values, by the inputbox method.<br />#<br /></span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxcomment"># start curly<br /><br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Enter your custom fonts below,<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># and remove the comment marker (#)<br /><br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># "" => "",<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># "" => "",<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># "" => "",<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># "" => "",<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># "" => "",<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># "" => "",<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># "" => "",<br /><br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Standard monospaced fonts that ship with Windows;<br /><br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"Bitstream Vera Sans Mono"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"VeraMono.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"Bitstream Vera Sans Mono Bold"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"VeraMoBd.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"Consolas"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"Consola.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"Consolas Bold"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"Consolab.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"Courier New"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"COUR.TTF"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"Courier New Bold"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"COURBD.TTF"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"DejaVu Sans Mono"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"DejaVuMonoSans.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"DejaVu Sans Mono Bold"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"DejaVuMonoSansBold.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"ISOCPEUR"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"isocpeur.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"ISOCP"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"isocp___.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"ISOCP2"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"isocp2__.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"ISOCP3"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"isocp3__.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"ISOCT"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"isoct___.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"ISOCT2"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"isoct2__.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"ISOCT3"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"isoct3__.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"ISOCTEUR"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"isocteur.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"Lucida Console"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"LUCON.TTF"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"Monospace 821 BT"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"monos.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"Monospace 821 Bold BT"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"monosb.ttf"</span><span class="syntaxkeyword">,<br /></span><span class="syntaxdefault">    </span><span class="syntaxstring">"Monotxt"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> </span><span class="syntaxstring">"monotxt_.ttf"<br /><br /></span><span class="syntaxkeyword">}</span><span class="syntaxdefault"> </span><span class="syntaxcomment"># end curly<br /></span><span class="syntaxkeyword">]<br /><br /></span><span class="syntaxdefault">  cd </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Dir</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">getwd<br />  Dir</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">chdir</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">expand_path</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dirname</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">)))<br /></span><span class="syntaxdefault">  File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">open</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'monofonts.txt'</span><span class="syntaxkeyword">,</span><span class="syntaxstring">'w'</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">io</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> io</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">puts</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">font_hash</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">  Dir</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">chdir</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">cd</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  <br />  cd</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">nil<br />  <br />  font_hash</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">nil<br />  GC</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start<br />  <br />  end </span><span class="syntaxcomment"># module<br /></span><span class="syntaxdefault">end </span><span class="syntaxcomment"># module         &nbsp;</span><span class="syntaxdefault"></span>
                This block form of the File.open method will automatically close the IO object when the block is finshed.
                The Ruby Docs are a bit confusing regarding IO and File, unless you realize that class File, is a subclass of class IO, and inherits all IO's methods. (A few of theses inherited methods are overriden in the File subclass, to make them explicitly work better for files.)
                I use the % string delimiters in the string defintion.
                %q is a single quoted string.
                %Q is a double quoted string.
                You can choose any delimiter you wish, which can either be the same character for the start and end delimiters, OR matched delimiters which are one of the bracket sets, ie { }, [ ], or ( ).
                Normally I like to use the curly brackets, but in this case since I'm wrapping a hash string (which is itself delimited by 'curlies',) I chose to use square brackets. (I could have still used curlies, but decided it might look confusing.)
                And it is normally good practice to wrap all IO operations within a begin ... rescue ... ensure clause. (I didn't do it because my uitilty only runs once.. and won't be distro'd.)
                Example:
                <span class="syntaxdefault">begin<br />  filename </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">'monofonts.txt'<br /></span><span class="syntaxdefault">  io </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">open</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">filename</span><span class="syntaxkeyword">,</span><span class="syntaxstring">'w'</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">io</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> io</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">puts</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">font_hash</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">rescue IOError </span><span class="syntaxkeyword">=></span><span class="syntaxdefault"> e<br />  UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Error writing file; #{filename}\n#{e.message}"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">ensure<br />  io</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close&nbsp;unless&nbsp;io</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">closed</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">end</span>
                I'm not here much anymore.
                  Aha! I had been trying to get string delimeters to work, and I had given up because I needed to use #{} notation inside my string, and I had only seen the %q example. I did not know that %Q acted as a duoble quotes. That will make things a little nicer. Thanks for all of that Dan and all,
                    Dan Rathbun
                    ..., and I had only seen the %q example. I did not know that %Q acted as a double quotes.
                    Actually % by itself is also a double-quoted string.
                    And also < and > can used as a bracket set, but I'm not sure I'd recommend it. (I'd prefer to save them for math expressions.)
                    You can nest brackets and quotes in strings:
                    adverb = 'really' str = %Q{"Hey, nested brackets #{adverb} do work!"}
                    >> "Hey, nested brackets really do work!"
                    str.inspect
                    >> ""Hey, nested brackets really do work!""
                    • JP2009J Offline
                      JP2009
                      How do you stop Sketchucation from downloading XML documents? It keeps doing this?
                        There's an issue with the recently updated PluginStore Extension when used in Chrome.
                        Disable that extension under Settings, until it is fixed...
                        Breaking news... v1.3 of that Extension was released today, it should fix the issue, so install that to update things, and those xml errors should be no more...
