    New Housing Model - A year in design
    16 Posts 7 Posters 1.4k Views 7 Watching
    • RichardR
      Richard
      @solo said:
      Great stuff mate.
      I'd like to see a 3d model to get a feel for the interior, I just cannot get 2D the way most folk can I need to feel depth and space, distance, width etc. (hard to explain but looking at the plan the passages feel so tight)
      Thanks Pete!!
      Mate the hallways are narrow, in fact everything is pretty much planned on what I'd normally consider a minimum. The reason simply being that they have to work on a standard site width of 15m.
      The hallways are currently at 900mm (roughly 3 feet), I've tried to counter this by providing larger (1500mm) sliding doors to the bedrooms hung on the bedroom side so even when closed that missing section of wall adds another 100mm to the hallway width.
      I was somewhat concerned at first with the narrow approach width to the one bed flat, but as it's open along one side I'd confident its ok!
      BUILTBRAND.COM.AU
      • RichardR
        Richard
        @pbacot said:
        Richard,
        One plan thing. in the combined plans, where the place belongs to one family group, you might blow out some of the wall dividing the carports (leave some closet or workbench in the center though). It feels funny if you are tinkering in one carport and wanting to go to the other or to another part of your house or property, you have to walk all the way out to the front.
        Thanks mate, I do like that idea. One one of the earlier sketch concepts I did look at the option to make that side of the garage light weight construction so that it could on conversion be opened with swing doors to the carport. In that instance I proposed gates to the carport the the whole garage and carport could be opened up as a secure covered play area for the kids. I've just got to confirm the fire rating required for the division between the two parking spaces prior to suggesting this is an option.
        Thanks again mate, for throwing back some ideas.
        BUILTBRAND.COM.AU
        • RichardR
          Richard
          @mike amos said:
          Well, those are just amazing what with the thought going into the variation and all. You know this is going to be the standard, I just hope you can see that. Render challenge or is it too sensitive for future designs?
          Thanks Mike!!!!! I certainly hope it does become the new standard for homes here in Australia at least. It certainly ticks almost all the prerequisites I'd set for the exercise.
          As we have an insurmountable housing shortage (even currently) and a growing issue with housing affordability this model certainly helps address these social issues. I've had discussions with several brokers to gauge the likely attitude of lending authorities - their opinions are that almost anyone would be granted finance given part of the home can always be used to generate an income to part fund the mortgage.
          Also given that the Granny Flat is much a fully independent entity as opposed to the current model it will always achieve maximum rental levels and higher occupancy levels. There is also some market concerns with the current model (granny flat to the rear) that the home could suffer in resale, and this concern is legitimate, though this concept counters that with the option of re-purposing the home at time of sale to meet the market demand.
          I might hold off on a render challenge just for now!
          BUILTBRAND.COM.AU
          • Bryan KB
            Very clever design!
            • RichardR
              Richard
              @bryan k said:
              Very clever design!
              As ALWAYS - Thanks Bryan!! πŸ‘
              BUILTBRAND.COM.AU
              • GarethG
                Gareth
                Well done mate. And congratulations in getting someone interested in helping get a display up and running.
                We have a dumb planning rule in SA which pops up in every Council's Development Plan now....they require garages and carports to be set back behind the face of the building (generally it is 500mm and for some councils it is 1200mm)...!
                Anyhow, it's nice to know someone is thinking about Granny...!
                • RichardR
                  Richard
                  Thanks mate! I totally agree with you on the STUPIDITY of that planning regulation of garages setback beyond the frontage, in fact for a number a design AND environmental reasons!
                  The most STUPID thing about it, I live in one of Sydney's most exclusive suburbs (only renting mind you), but seriously the homes and beauty of the place (Mosman) are stunning, you wont pick up a detached home under probably $3mil. And almost ALL the garages and carports are built to the boundary. How is it so that a place like this can be judged as one of Australia's most beautiful and sought after suburbs if this aspect would be considered "unattractive"???? Grrrrr Frekin Grrrrr!
                  Don't worry mate, if I get a builder in SA keen to license these designs (NSW, WA and TAS so far) I'll be going to the planning minister! But seriously I find in other states where similar regs stand, it's just a case of arguing the merits.
                  BUILTBRAND.COM.AU
                  • marked001M
                    marked001
                    Can't wait to see some 3D, as well. Although, I always love your simple, graphic 2d presentations.
                    http://www.revision21vis.com
                    instagram: revi21on
                    • GarethG
                      Gareth
                      Let me know if you need some contacts in Adelaide
                      • RichardR
                        Richard
                        Thanks mate, I may well take you up on that once I've got the whole concept better documented.
                        BUILTBRAND.COM.AU
