    Drop for 2014?
    17 Posts 7 Posters 1.6k Views 7 Watching
    • BoxB Offline
      a4rchitect SmartDrop Beta installed via the Sketchucation plugin works perfectly in SU2014.
      • KrisidiousK Offline
        Krisidious
        I right click on comp. hit smart drop at intersection and I get a hidden comp. where it had already been.
        By: Kristoff Rand
          Krisidious
          Throw to using the infinity option works. thanks.
          By: Kristoff Rand
            Krisidious
            Thanks Pilou, Cotty and Box for the quick suggestions.
            By: Kristoff Rand
            • srxS Offline
              srx
              DropGC on Smustard is working good.
              www.saurus.rs
              • BoxB Offline
                Throw to is one of my must have plugins.
                • ArcA Offline
                  Arc
                  It's an old plugin write by TBD.
                  And I change the file to rbz.
                  Now it's worked fine on 2014.
                  drop.rbz
                    Krisidious
                    Thanks Arc...
                    By: Kristoff Rand
                    • duanekempD Offline
                      duanekemp
                      Krisidious
                      I have a question for you and others here. Is there a "Drop to intersection" tool that selected components will not only drop but xyz align (rotate) itself to the face of the destination point? Typically, in the past, the drop at intersection does exactly that (drop a vertical tree on a slope and it remains vertical). However, to drop the tree on the slope and have it take the 90° of the face… Now that would be magic and what I'm rubbing the lamp for.
                      Is that what "smart drop" does?
                      Is there a drop plugin that will align the selected component to the face it intersects?
                      Thanks.
                      Duane Kemp
                      Kemp Productions
                      Puidoux, Switzerland
                      Gallery:
                      https://duanekemp.artstation.com/
                        Krisidious
                        Smart Drop Beta does it.
                        By: Kristoff Rand
                        • BoxB Offline
                          It's not a drop but you might find Components onto Faces handy too.
                          http://sketchucation.com/forums/viewtopic.php?p=138042#p138042
                            duanekemp
                            I just saw the reference of Kristoff and I will give this a try. Thank you so much. And thank you Kristoff for this: http://sketchucation.com/forums/viewtopic.php?t=3474
                            Duane Kemp
                            Kemp Productions
                            Gallery:
