    Drop for 2014?
    17 Posts 7 Posters 1.6k Views 7 Watching
      The new SketchyPhysics By Anton ? 😉
      Or more simple RayTracer By Thomthom should make the trick! 😉
      • cottyC
        cotty
        Another alternative: ThrowTo
        my SketchUp gallery
        • BoxB
          I'd be curious to know which ones you 'have' to see why they aren't working. Have you installed their latest version or have you moved them from an old plugin folder?
          • KrisidiousK
            Krisidious
            Currently I have a4rchitect SmartDrop Beta and the two Drops that come with SCF Powerbar.
            Yes, think I have latest versions of each and also tried just moving folder on the old SCF Powerbar. I'll try out these suggestions.
            By: Kristoff Rand
            • BoxB
              a4rchitect SmartDrop Beta installed via the Sketchucation plugin works perfectly in SU2014.
              • KrisidiousK
                Krisidious
                I right click on comp. hit smart drop at intersection and I get a hidden comp. where it had already been.
                By: Kristoff Rand
                • KrisidiousK
                  Krisidious
                  Throw to using the infinity option works. thanks.
                  By: Kristoff Rand
                  • KrisidiousK
                    Krisidious
                    Thanks Pilou, Cotty and Box for the quick suggestions.
                    By: Kristoff Rand
                    • srxS
                      srx
                      DropGC on Smustard is working good.
                      www.saurus.rs
                      • BoxB
                        Throw to is one of my must have plugins.
                        • ArcA
                          Arc
                          It's an old plugin write by TBD.
                          And I change the file to rbz.
                          Now it's worked fine on 2014.
                          drop.rbz
                          • KrisidiousK
                            Krisidious
                            Thanks Arc...
                            By: Kristoff Rand
                            • duanekempD
                              duanekemp
                              Krisidious
                              I have a question for you and others here. Is there a "Drop to intersection" tool that selected components will not only drop but xyz align (rotate) itself to the face of the destination point? Typically, in the past, the drop at intersection does exactly that (drop a vertical tree on a slope and it remains vertical). However, to drop the tree on the slope and have it take the 90° of the face… Now that would be magic and what I'm rubbing the lamp for.
                              Is that what "smart drop" does?
                              Is there a drop plugin that will align the selected component to the face it intersects?
                              Thanks.
                              Duane Kemp
                              Kemp Productions
                              Puidoux, Switzerland
                              Gallery:
                              https://duanekemp.artstation.com/
                              • KrisidiousK
                                Krisidious
                                Smart Drop Beta does it.
                                By: Kristoff Rand
                                • BoxB
                                  It's not a drop but you might find Components onto Faces handy too.
                                  http://sketchucation.com/forums/viewtopic.php?p=138042#p138042
                                  • duanekempD
                                    duanekemp
                                    I just saw the reference of Kristoff and I will give this a try. Thank you so much. And thank you Kristoff for this: http://sketchucation.com/forums/viewtopic.php?t=3474
                                    Duane Kemp
                                    Kemp Productions
                                    Gallery:
