    Drop for 2014?
    17 Posts 7 Posters 1.3k Views 7 Watching
    • KrisidiousK Offline
      Krisidious
      Is there a Drop for 2014? The ones I have aren't working... and on that note... Can someone fix the SCF Powerbar set?
      By: Kristoff Rand
        The new SketchyPhysics By Anton ? 😉
        Or more simple RayTracer By Thomthom should make the trick! 😉
        • cottyC Offline
          cotty
          Another alternative: ThrowTo
          my SketchUp gallery
          • BoxB Offline
            I'd be curious to know which ones you 'have' to see why they aren't working. Have you installed their latest version or have you moved them from an old plugin folder?
              Krisidious
              Currently I have a4rchitect SmartDrop Beta and the two Drops that come with SCF Powerbar.
              Yes, think I have latest versions of each and also tried just moving folder on the old SCF Powerbar. I'll try out these suggestions.
              By: Kristoff Rand
              • BoxB Offline
                a4rchitect SmartDrop Beta installed via the Sketchucation plugin works perfectly in SU2014.
                  Krisidious
                  I right click on comp. hit smart drop at intersection and I get a hidden comp. where it had already been.
                  By: Kristoff Rand
                    Krisidious
                    Throw to using the infinity option works. thanks.
                    By: Kristoff Rand
                      Krisidious
                      Thanks Pilou, Cotty and Box for the quick suggestions.
                      By: Kristoff Rand
                      • srxS Offline
                        srx
                        DropGC on Smustard is working good.
                        www.saurus.rs
                        • BoxB Offline
                          Throw to is one of my must have plugins.
                          • ArcA Offline
                            Arc
                            It's an old plugin write by TBD.
                            And I change the file to rbz.
                            Now it's worked fine on 2014.
                            drop.rbz
                              Krisidious
                              Thanks Arc...
                              By: Kristoff Rand
                              • duanekempD Offline
                                duanekemp
                                Krisidious
                                I have a question for you and others here. Is there a "Drop to intersection" tool that selected components will not only drop but xyz align (rotate) itself to the face of the destination point? Typically, in the past, the drop at intersection does exactly that (drop a vertical tree on a slope and it remains vertical). However, to drop the tree on the slope and have it take the 90° of the face… Now that would be magic and what I'm rubbing the lamp for.
                                Is that what "smart drop" does?
                                Is there a drop plugin that will align the selected component to the face it intersects?
                                Thanks.
                                Duane Kemp
                                Kemp Productions
                                Puidoux, Switzerland
                                Gallery:
                                https://duanekemp.artstation.com/
                                  Krisidious
                                  Smart Drop Beta does it.
                                  By: Kristoff Rand
                                  • BoxB Offline
                                    It's not a drop but you might find Components onto Faces handy too.
                                    http://sketchucation.com/forums/viewtopic.php?p=138042#p138042
                                      duanekemp
                                      I just saw the reference of Kristoff and I will give this a try. Thank you so much. And thank you Kristoff for this: http://sketchucation.com/forums/viewtopic.php?t=3474
                                      Duane Kemp
                                      Kemp Productions
                                      Gallery:
