    [plugin]Random replacement of components
    47 Posts 13 Posters 45.3k Views 13 Watching
      Sdmitch has made a new variant with no Random integrated! β˜€
      (see second post for more precsion of use πŸ˜‰
      31 May 2012
        A little tut πŸ˜‰
        No limite of number of any components source or target! πŸ‘
        You can name all your source components by hand but it's painfull when you have numerous!
        So a little trick πŸ˜‰
        Just select Components source and copy this in the ruby console
        Sketchup.active_model.selection.each{|c| c.name='Source'}
        Your source components are now named "Source"
        You can make the same for Target Component πŸ˜‰
        Sketchup.active_model.selection.each{|c| c.name='Target'}
        Edit : In fact for the rename Source and Target you can make the just with the Entity Info Box! πŸ’š
        You can now use the random plug πŸ˜‰ (click for zoom)
        Of course it's infinite possibilities πŸ˜’
        You can fill the space with no periodic infinite volumes πŸ’š
        you can play with this speedy one πŸ˜„
        Edit 31 May 2012
        A new variant without random is integrated!
        Dice2.skp
        renameInstances.rb
        31 May 2012
        • soloS Offline
          This is not working for me, Pilou can I send you a sample model by pm and you show how to do it?
            Of course yes you can! β˜€
            with a small file (sufficient for the concept) and a save as V7!!! πŸ˜‰
            • soloS Offline
              http://dl.dropbox.com/u/1129899/test%20tree.skp
              Strange how the size of file increases 50% when saving as SU7 from SU 8.
                Sorry it's always V8 when its arriving at home !!! πŸ˜‰
                • soloS Offline
                  Here is a SU 6 version
                  Dropbox - 404
                  (dl.dropbox.com)
                  • JBJDesignsJ Offline
                    JBJDesigns
                    This is an awesome plugin... thank you both very much!!! Jo πŸ˜„
                    ...you send them to school, you give them books, and they eat the pages...
                      coty82
                      This plugin is indeed great with so much potential. Do you think it could be possible to
                      make it able to replace child components that are inside mother componennts?
                      You could do so many patterns just by replacing components inside components.
                      • sdmitchS Offline
                        sdmitch
                        coty82
                        Please check Personal Messages.
                        http://sdmitch.blogspot.com/
                          coty82
                          Hello sdmitch
                          Thanks for the fast reply! I have installed it but unfortunatelly when i try to use it it just freezes Sketchup no matter if i choose to include child components or not. Is it working for you?
                            coty82
                            Update
                            I am trying to use it like this :
                            I have two components. One of them is named Target. I select them both and make them a mother component. This is how i was thinking of it to work.
                            I create another component named Source. When i use the plugin like this it just freezes.
                            But when i have two componenets and make them a group, and try to use the plugin, nothing happends, but it doesnt freeze neither.
                            Sorry i cannot reply in private because i dont have enough activity on the forums πŸ˜„
                            • sdmitchS Offline
                              sdmitch
                              @coty82 said:
                              Update
                              The plugin does not look for groups, components only. I see that the plugin has a bug, that I will fix, when there is only a single "Source" component. Create a second "Source" component and try again.
                              Check PM's for updated version.
                                coty82
                                Allright, it works now, thanks alot πŸ‘ ! But i noticed that it only works with a single level in the components hierarchy, that is when i have some individual components part of a mother component. But if i include this in another larger component, it doesnt work. Even if i copy the source inside the larger component. Its still great but i wonder if this would be a difficult property to implement?
                                Anyway i have another ideea about it πŸ˜„ . In a previous post you said it is also able to replace components based on a rule? For example i have 3 sources 1, 2, 3 And i want to distribute them according to a repeating pattern for ex 11231123, etc. They could replace an array of targets. This would be amazing for creating panelling patterns for facades for example. But it would probably need to work with something like series, to know the start and ending point. Dunno if its possible or how complicated?
                                • sdmitchS Offline
                                  sdmitch
                                  Yes, it currently will only work for one level, mother and child, no grand kids.
                                  As the name implies, it is supposed to be a random replacement.
                                    coty82
                                    I see there is another version with No random option, how is it working? I tried but i didnt see a difference.
                                    • sdmitchS Offline
                                      sdmitch
                                      Component Replacement has a random option which, if not selected, causes the "Target" components to be replaced in order by the "Source" components. The results is dependent on the order the "Source" components are found in the model or selection.
                                        coty82
                                        Oh i see. And what is the rule by which it finds the "Source" components? It always gives me the same result but the initial order seems random. I couldnt replicate your example where you have components 1, 2, 3 which then become a repeated sequence in the target. Could you also integrate this no random feature in the version with child option as well? πŸ˜„ Thanks
                                          Can you post an image of results of this new version (parent / child) ?
                                          • sdmitchS Offline
                                            sdmitch
                                            The result looks the same.
                                            • 2 / 3
