    [plugin]Random replacement of components
    47 Posts 13 Posters 48.0k Views 13 Watching
    • soloS Offline
      http://dl.dropbox.com/u/1129899/test%20tree.skp
      Strange how the size of file increases 50% when saving as SU7 from SU 8.
        Sorry it's always V8 when its arriving at home !!! πŸ˜‰
        • soloS Offline
          Here is a SU 6 version
          Dropbox - 404
          (dl.dropbox.com)
          • JBJDesignsJ Offline
            JBJDesigns
            This is an awesome plugin... thank you both very much!!! Jo πŸ˜„
            ...you send them to school, you give them books, and they eat the pages...
              coty82
              This plugin is indeed great with so much potential. Do you think it could be possible to
              make it able to replace child components that are inside mother componennts?
              You could do so many patterns just by replacing components inside components.
              • sdmitchS Offline
                sdmitch
                coty82
                Please check Personal Messages.
                http://sdmitch.blogspot.com/
                  coty82
                  Hello sdmitch
                  Thanks for the fast reply! I have installed it but unfortunatelly when i try to use it it just freezes Sketchup no matter if i choose to include child components or not. Is it working for you?
                    coty82
                    Update
                    I am trying to use it like this :
                    I have two components. One of them is named Target. I select them both and make them a mother component. This is how i was thinking of it to work.
                    I create another component named Source. When i use the plugin like this it just freezes.
                    But when i have two componenets and make them a group, and try to use the plugin, nothing happends, but it doesnt freeze neither.
                    Sorry i cannot reply in private because i dont have enough activity on the forums πŸ˜„
                    • sdmitchS Offline
                      sdmitch
                      @coty82 said:
                      Update
                      The plugin does not look for groups, components only. I see that the plugin has a bug, that I will fix, when there is only a single "Source" component. Create a second "Source" component and try again.
                      Check PM's for updated version.
                        coty82
                        Allright, it works now, thanks alot πŸ‘ ! But i noticed that it only works with a single level in the components hierarchy, that is when i have some individual components part of a mother component. But if i include this in another larger component, it doesnt work. Even if i copy the source inside the larger component. Its still great but i wonder if this would be a difficult property to implement?
                        Anyway i have another ideea about it πŸ˜„ . In a previous post you said it is also able to replace components based on a rule? For example i have 3 sources 1, 2, 3 And i want to distribute them according to a repeating pattern for ex 11231123, etc. They could replace an array of targets. This would be amazing for creating panelling patterns for facades for example. But it would probably need to work with something like series, to know the start and ending point. Dunno if its possible or how complicated?
                        • sdmitchS Offline
                          sdmitch
                          Yes, it currently will only work for one level, mother and child, no grand kids.
                          As the name implies, it is supposed to be a random replacement.
                            coty82
                            I see there is another version with No random option, how is it working? I tried but i didnt see a difference.
                            • sdmitchS Offline
                              sdmitch
                              Component Replacement has a random option which, if not selected, causes the "Target" components to be replaced in order by the "Source" components. The results is dependent on the order the "Source" components are found in the model or selection.
                                coty82
                                Oh i see. And what is the rule by which it finds the "Source" components? It always gives me the same result but the initial order seems random. I couldnt replicate your example where you have components 1, 2, 3 which then become a repeated sequence in the target. Could you also integrate this no random feature in the version with child option as well? πŸ˜„ Thanks
                                  Can you post an image of results of this new version (parent / child) ?
                                  • sdmitchS Offline
                                    sdmitch
                                    The result looks the same.
                                    • sdmitchS Offline
                                      sdmitch
                                      I have added the recursive search to my Component Replacement plugin. You can obtain a copy from my blog page. This is a total replacement for the original Random Component Replacement plugin.
                                        Thx, I will explore this new opus! β˜€
                                          AcesHigh
                                          It would be really nice if we could set % of random replacement.
                                          example:
                                          have a building with 300 closed window components. These will be the target
                                          then we also have 4 other window components that will be used as sources: totally opened window, 3/4 opened window, half opened window and 1/4 opened window
                                          this plugin, as it is, will replace ALL closed windows with a random number of each of the other 4 windows.
                                          but it would be ideal if we could decide to make random ONLY which components will be replaced, not the number.
                                          So...
                                          Original Component Remaining: 30% (I set to 30% so 30% of the 300 closed windows will remain as the "closed window" component
                                          Source 1 - 10% (of 300)
                                          Source 2 - 20%
                                          Source 3 - 30%
                                          Source 4 - 10%
                                          After the operation, in random locations of the building, we would have
                                          90 closed windows (original component)
                                          30 4/4 open windows
                                          60 3/4 open windows
                                          90 half open windows
                                          30 1/4 open windows
                                            Just build the source with your result % wished! πŸ˜‰
                                            It's not a big deal to make some copy move for build your sets of %! πŸ˜‰
                                            4 seconds * 16 cases = 1 minute πŸ˜„
                                            • 2 / 3
