    [plugin]Random replacement of components
    47 Posts 13 Posters 47.6k Views 13 Watching
      @Edson πŸ˜„
      No, Source and Target are not nescessary names πŸ˜‰
      It's just these given by default in the dialog box πŸ˜‰
      you can put any names you want πŸ˜„ (of course these that you have yet renamed your components in the Info Box πŸ˜‰
      But carreful it's sensitive cases !!!
        And here the 24 positions plug of Sdmitch πŸ˜‰
        With his autorisation! 😎
        Pilou24Positions.rb
          AcesHigh
          there are many uses for this plugin.
          for example... think of 3D tiles on a roof. Each tile is a component. But the roof gets so artificial, with all the tiles exactly the same color, no stains, etc. With this plugin, you would be able to, for example, create some 10 different roof tiles, each of them a slight different color variation, some stains, etc. And randomly replace the original components along the entire roof.
          another possibility: a building with a glass faΓ§ade. Real such buildings will have curtains/blinds behind the windows. Make the the building with window components. The random replace them with OTHER window components, each window component with blinds in different positions (no blinds, blinds half way pulled, pulled down completely)
          there are so many uses!!!
            rachmatrf
            Thhank you Sdmitch
              Sdmitch has made a new variant with no Random integrated! β˜€
              (see second post for more precsion of use πŸ˜‰
              31 May 2012
                A little tut πŸ˜‰
                No limite of number of any components source or target! πŸ‘
                You can name all your source components by hand but it's painfull when you have numerous!
                So a little trick πŸ˜‰
                Just select Components source and copy this in the ruby console
                Sketchup.active_model.selection.each{|c| c.name='Source'}
                Your source components are now named "Source"
                You can make the same for Target Component πŸ˜‰
                Sketchup.active_model.selection.each{|c| c.name='Target'}
                Edit : In fact for the rename Source and Target you can make the just with the Entity Info Box! πŸ’š
                You can now use the random plug πŸ˜‰ (click for zoom)
                Of course it's infinite possibilities πŸ˜’
                You can fill the space with no periodic infinite volumes πŸ’š
                you can play with this speedy one πŸ˜„
                Edit 31 May 2012
                A new variant without random is integrated!
                Dice2.skp
                renameInstances.rb
                31 May 2012
                • soloS Offline
                  This is not working for me, Pilou can I send you a sample model by pm and you show how to do it?
                    Of course yes you can! β˜€
                    with a small file (sufficient for the concept) and a save as V7!!! πŸ˜‰
                    • soloS Offline
                      http://dl.dropbox.com/u/1129899/test%20tree.skp
                      Strange how the size of file increases 50% when saving as SU7 from SU 8.
                        Sorry it's always V8 when its arriving at home !!! πŸ˜‰
                        • soloS Offline
                          Here is a SU 6 version
                          Dropbox - 404
                          (dl.dropbox.com)
                          • JBJDesignsJ Offline
                            JBJDesigns
                            This is an awesome plugin... thank you both very much!!! Jo πŸ˜„
                            ...you send them to school, you give them books, and they eat the pages...
                              coty82
                              This plugin is indeed great with so much potential. Do you think it could be possible to
                              make it able to replace child components that are inside mother componennts?
                              You could do so many patterns just by replacing components inside components.
                              • sdmitchS Offline
                                sdmitch
                                coty82
                                Please check Personal Messages.
                                http://sdmitch.blogspot.com/
                                  coty82
                                  Hello sdmitch
                                  Thanks for the fast reply! I have installed it but unfortunatelly when i try to use it it just freezes Sketchup no matter if i choose to include child components or not. Is it working for you?
                                    coty82
                                    Update
                                    I am trying to use it like this :
                                    I have two components. One of them is named Target. I select them both and make them a mother component. This is how i was thinking of it to work.
                                    I create another component named Source. When i use the plugin like this it just freezes.
                                    But when i have two componenets and make them a group, and try to use the plugin, nothing happends, but it doesnt freeze neither.
                                    Sorry i cannot reply in private because i dont have enough activity on the forums πŸ˜„
                                    • sdmitchS Offline
                                      sdmitch
                                      @coty82 said:
                                      Update
                                      The plugin does not look for groups, components only. I see that the plugin has a bug, that I will fix, when there is only a single "Source" component. Create a second "Source" component and try again.
                                      Check PM's for updated version.
                                        coty82
                                        Allright, it works now, thanks alot πŸ‘ ! But i noticed that it only works with a single level in the components hierarchy, that is when i have some individual components part of a mother component. But if i include this in another larger component, it doesnt work. Even if i copy the source inside the larger component. Its still great but i wonder if this would be a difficult property to implement?
                                        Anyway i have another ideea about it πŸ˜„ . In a previous post you said it is also able to replace components based on a rule? For example i have 3 sources 1, 2, 3 And i want to distribute them according to a repeating pattern for ex 11231123, etc. They could replace an array of targets. This would be amazing for creating panelling patterns for facades for example. But it would probably need to work with something like series, to know the start and ending point. Dunno if its possible or how complicated?
                                        • sdmitchS Offline
                                          sdmitch
                                          Yes, it currently will only work for one level, mother and child, no grand kids.
                                          As the name implies, it is supposed to be a random replacement.
                                            coty82
                                            I see there is another version with No random option, how is it working? I tried but i didnt see a difference.
                                            • 2 / 3
