    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 357.3k Views 109 Watching
    • deaneauD Offline
      deaneau
      @sdmitch said:
      Sorry but FloorGenerator only works on faces not surfaces. Even if hidden geometry is not displayed, when you pick a point on the surface you select just one of the faces that make up the surface.
      You could create a face with the overall dimensions of the surface. Then use Shape Bender to produce the curved surface after applying the tile pattern. A bit of work but all I can offer at this time.
      yes this i have try before i asking here, with Fredo Scale ( Radial Bending)
      what you mean is Chris Fullmer Shape Bender.
      i have never tried it before.
      ok, this work.
      now i have a problem. the segments have not the exact lenght.
      your plugin AddPts2Curve was my help, to see where on the curve is the 1,2m point and the next etc.
      I will try step by step all your plugins.
      Helper like plugins will every time be welcome.
      thank you
        tomot
        @sdmitch Its the first time I see HTML code embedded in a Ruby script. Thanks for not using .rbs
        It gives me some confidence and a template to redo some of my scripts incorporating HTML. πŸŽ‰
        Finally I have an example & see how with HTML I can place pictures next to my drop-down boxes.
        cheers!
        [my plugins](http://thingsvirtual.blogspot.ca/)
        tomot
        • sdmitchS Offline
          sdmitch
          That's the way I learned what little I know.
          http://sdmitch.blogspot.com/
          • deaneauD Offline
            deaneau
            Hello Sam,
            is it possible to insert the feature that tiles is grouped?
            actually if i generate a floor i have only a main group.
            when tiles is grouped i can do random rotate with mover2.
            this will look a little bit more inperfect.
            in mover i can use random rotation in x,y or z axis and can insert the degree by value.
            thank you
            Dean
            • sdmitchS Offline
              sdmitch
              @deaneau said:
              Hello Sam,
              Do you mean each individual brick is a group?
              That is what the "Random Imperfections" option is for. That feature was fixed and enhanced in the last update on 21-Sep
              thank you
              Dean
              [attachment=1:1zcdcsd3]<!-- ia1 -->_2014.10.07_23h12m17s_019_01006.jpg<!-- ia1 -->[/attachment:1zcdcsd3]
              [attachment=0:1zcdcsd3]<!-- ia0 -->_2014.10.07_23h29m06s_020_01007.jpg<!-- ia0 -->[/attachment:1zcdcsd3]
              • deaneauD Offline
                deaneau
                i have seen your plugin "Random Rotation".
                in this plugin you could insert 3 checkmarks for x y z-axis.
                so i have the control for axis. actually looks that the rotation work in all axis.
                like this
                • deaneauD Offline
                  deaneau
                  the random inperfection rotate in all axis.. some times i would have only a rotation in z-axis. a value in degree is helpful.
                  when all tiles would be in own group..so i could work with mover2 and in the last step ungroup this tiles.
                  ungrouping go faster than grouping if i have tiles more than 1000+ .
                  thank you
                  • sdmitchS Offline
                    sdmitch
                    like this
                    [attachment=0:2bd2nz7e]<!-- ia0 -->_2014.10.09_09h12m14s_003_01011.jpg<!-- ia0 -->[/attachment:2bd2nz7e]
                    That plugin is for rotating whole components or groups not individual entities within the component or group.
                    • deaneauD Offline
                      deaneau
                      yes ..ok no problem
                      • deaneauD Offline
                        deaneau
                        Hello Sam,
                        i have a project for this i would use your FloorGenerator.
                        i know that you have a random textur feature in this plugin.
                        what do you think about to integrate a feature that doing follow:
                        i have 10 different pattern and i would use 10 different texture packs.
                        a approach to solving this problem could be that all textures have a prefix.
                        for example.
                        A_Texture1,A_Texture2,A_Texture3 etc
                        B_Texture1,B_Texture2,B_Texture3 etc.
                        A_ B_ C_ etc is the prefix.
                        Texture1, Texture2 is a placeholder for my own given name.
                        when i use in the first step the Tile Pattern and i will use a texture pack A_
                        dropdown menue let me choose the Prefix A_
                        in the next step i would use Brick Pattern with TexturePack B_
                        i choose only in the dropdown the Prefix B_
                        this textures with a given Prefix i want use for your Random texture feature.
                        actually i must change the textures in the texture folder when i want have different textures in the next step.
                        if the floor is generated i would have all parts in own groups.
                        actually the floors is only in one main group.
                        why i would have this features.
                        the workflow after integrating this feature would be more faster and when the objects is in own groups i can animate this in other programs.
                        download here
                        Page Not Found
                        Web word processing, presentations and spreadsheets
                        (drive.google.com)
                        thank you
                        p.s.component is better than groups i think
                        • deaneauD Offline
                          deaneau
                          Hello,
                          i have had a problem with random texture.
                          my result was this:
                          after renaming all textures with a prefix i have solve this problem
                          result:
                          here a example for file renaming:
                          and here a freeware to remame files with your favorit prefix etc.
                          Download for Windows and Mac - Advanced Renamer
                          Download the batch renamer, Advanced Renamer for Windows and macOS.
                          (www.advancedrenamer.com)
                          πŸ‘ πŸ‘ many thanks at Sam for the hard work for the Floor Generator πŸ‘ πŸ‘
                            deadakos
                            I was looking for such a tool for SketchUp so long! Thanks for it!
                            I'm playing with the plugin now, and I have a questions:
                            • is there a way to limit the used quantity of the colors in "Rand_clr" mode?
                            • sdmitchS Offline
                              sdmitch
                              Sorry but no.
                                logan683
                                What is the latest version of this plugin? This is different than the one downloaded straight from the SketchUcation store in SU.
                                Also, you can't change the size of the pattern?? I want to set a 10' long wood board pattern, but it's stuck on 10" and won't accept any changes.
                                Does this work correctly at all?
                                • sdmitchS Offline
                                  sdmitch
                                  21-Sep-2014 is the latest version. The plugin is setup for inches or millimeters so 10' is not valid, enter 120 instead.
                                    lothian
                                    This tool has the potential to be an indispensable time-saving utility for visualizing tile layout. For example, the capability to use the actual images of tile to visualize their position within a layout is absolutely wonderful. As one who sees the prospect of this utility, I offer the following feature suggestions to extend its usefulness even further:
                                    1. Add a 'Pattern Reset' button.
                                      Move pattern reset from its present location under the pattern drop menu to its own dedicated button on the main options palette.
                                    2. Save current settings when the plugin closes.
                                      Presently, settings reset to default when the FloorGenerator plugin closes.
                                    3. Add the option to prevent "texture adjacency".
                                      This suggestion requires some explanation. Applies to tile with images/patterns/designs, where 1) images/patterns/designs are randomly distributed within a grid BUT, 2) images/patterns/designs must not be adjacent. Presently, the FloorGenerator plugin's randomization permits instances where two identical textures are adjacent. Allow the option to prevent any instance from occurring where the same tile is adjacent along horizontal, vertical or diagonal axes. This option would only be relevant above a certain min. threshold of unique tiles. This ability is, in my opinion, the most important potential feature of the plugin.
                                    4. Add a "1:1 Texture Scale" button.
                                      A button that instantly matches tile size values to tile image at 1:1 would be a valuable convenience.
                                    5. Add a material selection browser box.
                                      Replace the current requirement of coping tile texture images to a specific location (within the plugin folder) with the ability to browse and select any custom location. That location is saved when the plugin is closed.
                                    • sdmitchS Offline
                                      sdmitch
                                      1. The current "Reset" option, returns all patterns to there default settings and was something I assumed would be rarely used. I guess that's not the case for you?
                                      2. The individual "Pattern" settings are maintained from session to session. The only thing not currently retained is the Pattern Option itself which defaults to Tile. If this is not the case for you, perhaps you have an old version? I will add code to save last Pattern selected.
                                      3. An easy thing to see visually but would be a major task to code I think.
                                      4. Could be applicable to some Patterns but not all. I will give it some thought.
                                      5. This is something I did sometime ago. Guess I forgot to post that version.
                                        rhinoferoce
                                        Hello ! I would love to try this plugin that seems very helpful, but I'm unable to find it within the pluginstore (toolbar or website).
                                        Can you help me to find it ?
                                        Thank you very much...
                                          driven
                                          did you try Sam's website?
                                            arqjonatan
                                            Hello, i want to ask, is this plugin already avalible for sketchup 2015?
                                            • 16
                                            • 17
                                            • 2 / 17
