    [Plugin] [$] S4u_Panel
    25 Posts 12 Posters 15.5k Views 12 Watching
    • JQLJ
      JQL
      You're in a spree! Well done!
      www.casca.pt
      Visit us on facebook!
      • G
        g.moggel
        wonderful. very useful for real architecture models where you would rebuild your 3d building into cardboards. what would be nice though is a tool to automatically create 2 of the boards sitting inside the other when using the tool last shown in the video.
        cheers,
        shut up and take my money πŸ˜‰
        mo
          sancho77
          πŸ‘ She is a beauty!
          • GMthompsonG
            GMthompson
            HMMMMM Its like a improved double line.rb looks like a winner
            you can learn something everyday by paying attention
            • F
              function
              s4u_on_fire thanks for all the great plugins this past month!
              • hdpvH
                hdpv
                After s4u toComponent v5.0.0 to finish πŸ˜‰
                Suforyou
                http://www.sketchupforyou.com
                • F
                  feodos
                  The plug-in doesn't work. The table doesn't appear.. SU2014
                  • C
                    chrisik
                    Same here.
                    • hdpvH
                      hdpv
                      What OS do you use?
                      copy message Ruby Console (in menu Windown-> Ruby Console) send to me
                      RightMouse for get Options and Set parameter
                      Suforyou
                      • F
                        feodos
                        Win7-64
                        Ruby Console:
                        Error: #<ArgumentError: Cannot convert "3.5cm" to Length>
                        c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:94:in to_l' c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:94:in reset_setting'
                        c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:63:in activate' c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:662:in select_tool'
                        c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:662:in main' C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_menu.rb:19:in block (2 levels) in module:S4u_panel'
                        -e:1:in call' Error: #<TypeError: no implicit conversion to float from nil> c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:270:in length='
                        c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:270:in get_points_panel' c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:199:in draw'
                        c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:270:in length=' c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:270:in get_points_panel'
                        c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:199:in draw' Error: #<TypeError: no implicit conversion to float from nil> c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:270:in length='
                        c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:199:in draw' Error: #<TypeError: no implicit conversion to float from nil> c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:473:in pushpull'
                        c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:473:in make_panel' c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:435:in process_panel'
                        c:/users/admin/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/s4u_panel/s4u_panel_code.rbs:379:in `onLButtonDown'
                        • hdpvH
                          hdpv
                          I have fixed it.
                          Try again!
                          Suforyou
                          • F
                            feodos
                            ok, thanks
                            • G
                              goga63
                              when you download the new version error
                              Error Loading File C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_code.rb
                              Error; #<SyntaxError; C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_code.rb;665; syntax error, unexpected keyword_end, expecting end-of-input>
                              C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_menu.rb;9;in `require'
                              C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_menu.rb;9;in `<module;S4u_panel>'
                              C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_menu.rb;5;in `<module;S4U>'
                              C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_menu.rb;3;in `<top (required)>'
                              C;/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb;197;in `require'
                              C;/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb;197;in `load'
                              C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel.rb;16;in `register_extension'
                              C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel.rb;16;in `<module;S4u_panel>'
                              C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel.rb;4;in `<module;S4U>'
                              C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel.rb;3;in `<top (required)>'
                              • hdpvH
                                hdpv
                                Run as Administrator Sketchup
                                install plugin and restart.
                                I don't know this error.
                                Suforyou
                                • G
                                  goga63
                                  thanks, it works now.
                                  • designerbursaD
                                    designerbursa
                                    s4u please part list an cutting nesting
                                    Than you
                                    • hdpvH
                                      hdpv
                                      i don't understand!
                                      Suforyou
                                      • G
                                        greatoe
                                        the TAB key for Front-Middle-Back never work on a Mac
                                        • hdpvH
                                          hdpv
                                          Did you update the new version?
                                          What is your system?
                                          Suforyou
                                            AISmebel
                                            Hey. I want to clarify with you if the plugin is being updated if I bought it on extensions.sketchup.com? The fact is that my version is v1.3, but v1.4.8 is listed on sketchucation.com.
                                            What do I need to do to upgrade to v1.4.8?
                                            I have one more question for you. Is it possible to remove the sticking of the cursor to 1/3? I do not need this function and it really bothers me.
