    Help Contour Road
    13 Posts 4 Posters 5.1k Views 4 Watching
    • I
      imabzeous
      I don't remember is this tutorial is in English, but you have several images! ๐Ÿ˜„
      By Daredevil
      not authorize to download ๐Ÿ˜•
      • pbacotP
        You do have the basic problem that real roads do not follow terrain only, but require cut and fill to level and even them out, more or less. That's where "InstantRoad" will help. There ARE some other approaches. I remember some posts, that you could search for. If this is for learning or testing methods, you might try some runs on a much simpler model first, to save some headaches. I wonder what you expect (whichever) Artisan function you used to do for you.
        • pbacotP
          Here is one tutorial http://sketchucation.com/forums/viewtopic.php?f=18%26amp;t=19522
          • I
            imabzeous
            I have already worked on simple contours and know but this one am stuck ๐Ÿ˜ž
            and if you look at this video at 5:00 min you can see he use artisian make planar tool and it worked like a charm.
            • soloS
              You mean around 5m 50 mark, that does work when your initial terrain is subdivided enough your terrain needs more subdivision before trying that.
              • I
                imabzeous
                You are the savior SOLO ๐Ÿ’š
                I ll do it in the morning at lab and thank you so much
                  I don't remember if this tutorial is in English, but you have several images! ๐Ÿ˜„
                  By Daredevil
                    Very mysterious! ๐Ÿ˜ฎ
                    And here following ?
                    Route.pdf
                    • I
                      imabzeous
                      Btw can anyone tell is there anyway to slect edges and vertice and cerease them? am manually clicking each vertice and edge?
                      • I
                        imabzeous
                        I am done with the contours, but there is something i would like to ask all of you, i have created it in parts, in parts artisan planner option works well but full road it wont . any reason? i just want to learn it and want to know its logic so if anyone can explain it to me?
