    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 181.6k Views 109 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      I have no idea, but you could send me your whole Plugins folder, and I'll investigate when I have time. (In at least two weeks)
      • danchoD Offline
        dancho
        Hi jiminy-billy-bob,
        I like your plugin but I found some strange thing.
        There is a differende between content of builn in layer window
        and your plugin. In the built in there is sometimes more layer
        than in yours.
        OS_win7 home prem. x64
        IE_11.0.9600.17239
        SU_2014 latest
        BR.
        Daniel
        difference
        • F Offline
          fountainhead
          The offending plugin is eneroth 3D rotate. With associated . rb file removed, no layer loading issues.
            glro
            i have strange behaviours with Layers panel, and i use eneroth 3D rotate too...
            any suggestion to modify one or both plugins to make them work together?
              jiminy-billy-bob
              New version 1.2.1 !
              Changelog :
              • Fixed a major issue that could corrupt the model (Caused by SU14 and below)
              • Fixed States dialog
              • Added API methods
              Download in the plugin store !
                glro
                @jiminy-billy-bob said:
                New version 1.2.1 !
                Changelog :
                • Added API methods
                thank you
                i give it a try to check if it solves the issues i had
                when i launch the plugin for the first time in a model made before the installation, an almost empty layers panel window opens, with only one layer, and i get a message "layers panel needs to be fixed"; i click "OK"
                An html windows pops up, saying no issues are detected...
                I close the pop up window and the empty layers panel window
                The next time i open the layers panel window, all layers are shown
                close the model, open it again ...
                everything seems to be working fine...
                no issues detected
                  jiminy-billy-bob
                  This is normal behaviour. It is triggered by the fact that there are existing layers that need to be identified by LP. This is a one-time thing, and won't trigger again (unless there are layers created while LP is disabled).
                  Maybe I should change it to say that issues have been fixed, not only that there are no issues. It may be misleading as is.
                  Do you guys still have issues with Eneroth's Rotate3D? I can't reproduce your errors.
                    glro
                    yes, maybe the message is not totaly accurate ; there is no problem;it is just that the existing layers must be registered by layers panel plugin
                    somebody suggested that there was a conflict between Eneroth's Rotate 3D and your plugin, but gave no evidence; so i don't know about it; i shall be using layers panel in the coming daus, and i also run Rotate 3D code, so if i notice something wrong, i shall report it
                      glro
                      I have been using your "layers panel.rb" for 2 or 3 days, it worked fine
                      but today, it proved to be not compatible with a plugin containing rotate3D code
                      i am not skilled enough to say why, but it seems to confirm there is a problem...
                      too bad, it improves a lot the sketchup native layers panel
                        jiminy-billy-bob
                        Did you get an error message?
                        What happened exactly?
                          glro
                          sketchup stopped suddenly, and that was it
                          bugsplat
                          i tried to remove some newly installed extensions, and this way i found out that "Layers panel" was involved
                          I can't write more since i don't understand what's happening; your plugin might be perfect; i just know that if i remove it, i don't have the problem
                          • tt_suT Offline
                            tt_su
                            Did you submit that BugSplat? Did you enter any info in the Description or Name field we can use to look it up by?
                              glro
                              No
                              but if you think it might help, i shall
                              • tt_suT Offline
                                tt_su
                                We might be able to get some clues to what cause the crash.
                                Please always submit BugSplats - even if you do not fill in any info. It helps our statistic when we look for highest source of crashes. But it do helps if you enter some info the first time you experience a crash, and some contact info so we can reach out if we need more info. Then if you experience the crash again just keep submitting, but then there is less need for you to fill out details.
                                  Layer One
                                  I love it, great plugin.
                                  Is there any way to sort the layers, perhaps alphabetically.
                                    jiminy-billy-bob
                                    No, not for now, but it's on my todo list.
                                      alexpnz
                                      Hello !
                                      Huge thanks for a great plugin !
                                      I SUMake 2014 on Mac OS X 10.8.5 there is a problem:
                                      1. Toolbar Layers Panel disappears after you restart the program, it is necessary to re-run. If you add buttons to the toolbar after restart, SU they also disappear from the panel.
                                      2. On the panel Layers Panel toggle visibility is not clicking on the "eye" and slightly to the left of the separator (assuming off-panel renders) and Layer switching States of the active set is not pressing on the circle and also slightly to the left of the separator.
                                      3. The Panel Layer States every time you open appears in the same place (it does not remember its position).
                                      4. the Panel Layers Panel if it is to disable and enable the button from the toolbar Layers Panel every time you open becomes shorter height)) cool.
                                      Sorry for machine translation)
                                        ckho1985
                                        running OS X 10.8.5, sketchup 14.
                                        I updated the layer panel 1.2.1 from 1.2.0. but then the tool does not work anymore.
                                        It is clearly intalled. The icon is there. the Layer Status browser works, when clicking the icon. But the Layer Panel does not open when clicking the icon. The browser window of the Layer Panel sort of flashes once which clicking the icon. (open and closes in a 0.1 second)
                                        dont know what to do.
                                        Great tool! frustrated that cannot us it now…. arrrrghhh
                                          jiminy-billy-bob
                                          Can you open the Ruby Console, and tell me if there is any error message there when trying to open Layers Panel?
                                          In the meantime, you can download older versions here: http://thomashauchecorne.com/layers/versions/
                                          (Please try the above first, so I can fix it for future versions)
                                            ckho1985
                                            Do I need to type anything in the ruby console?
                                            there is no error message. Everything else (debug, option, status) works fine.
                                            just when I click layer panel the window is not showing up (it flashed up then its gone)
                                            I tried to uninstall 1.2.1 and reinstall 1.2.0. same thing happens.
                                            maybe is the sketchup itself has a problem?
                                            • 33
                                            • 34
                                            • 5 / 34
