    [Plugin] Raytracer
    60 Posts 18 Posters 69.3k Views 18 Watching
      AcesHigh
      @tt_su said:
      Hard to tell without a model...
      Sorry, but when I posted and attached the model, I didnt notice it failed to upload the model because it was larger than the 4mb forum attachment limit.
      I edited the first post and attached the model (now, 3mb)
      • BoxB
        I used the plugin "Throw to".
        Throw toSU8.skp
          AcesHigh
          Thank you Box. Any slight idea why Raytracer, Drop At Intersection, etc, are not working?
          • BoxB
            Sorry, I don't know the ins and outs of either plugin. Which is why I went for throw to. I can look tomorrow if nobody else does.
            • tt_suT
              tt_su
              It appear to be because the ray traced hit the component it tried to drop. Apparently I forgot to make it ignore itself. If I moved the axis to the bottom of the component it worked fine.
              • tt_suT
                tt_su
                Filed issue: https://bitbucket.org/thomthom/raytracer/issue/1/ignore-the-components-being-dropped
                  AcesHigh
                  I see. Thanks ThomThom, for looking at the issue.
                    mlefevre
                    @tt_su said:
                    No idea without test screenshots or preferable a test model.
                    I can send you a screenshot, but basically I'm having the same issue as one of the prior post with the car crashes.
                    • tt_suT
                      tt_su
                      SketchUp crashes?
                      What version of SketchUp are you using (full exact version please) and what OS?
                      Got a sample model and step by step description of what you do to reproduce it?
                        DCorral
                        I'm new on sketchup and seem to not understand this plugin. I did a toposurface and modeled all the constructions on a big area. Now im trying to drop the components (i'm guessing it's going to be a lot of work but I'm fine with that) and I can't seem to be able to drop them into the terrain... They keep floating.. want to try raytracing but i dont understand that function.
                        Could you help me? Thanks a lot.
                        • P
                          Panga
                          DCorral,
                          One thing you have to verify is the position of your axes inside the component. The origin of axes must be at the bottom of the geometry in order that the drop works.
                          Hope it helps.
                          Regards.
                            Always cool! 😄
                            • E
                              eph
                              Hey Thomthom,
                              Spraycan crashes my SU every time I use it.. 😐
                              I'm on OS X 10.9.5, latest SU 2014.
                              Really easy to reproduce: open a new SKP (I work in mm or cm), draw a rectangle on the ground plane, select the default component ("Sophie") and spray her on the surface (radius 250 cm). Crashes every time... Of course it also happens in more complicated models.
                              Could you please check / fix?
                              Thanks in advance!!
                              • tt_suT
                                tt_su
                                Hm..
                                Did you submit the BugSplats?
                                If you did, did you enter any info in the description or name that I can use to look it up? If you didn't, can you submit one and add some info I can use to look it up in the database?
                                • E
                                  eph
                                  @tt_su said:
                                  Hm..
                                  Hey Thomthom, just did. Mentionned Raytracer in the description, filed under the name "eph".
                                  Thanks for the quick reaction 😄
                                  • tt_suT
                                    tt_su
                                    Found it! I'll inspect. Thanks.
                                    • tt_suT
                                      tt_su
                                      By the way, what version of Raytracer and TT_Lib do you have installed? (Can you verify with full version numbers reported under Preferences > Extensions please?)
                                      • E
                                        eph
                                        Up to date on the Sketchucation Plugin Store:
                                        TTLib2 v2.9.13, Raytracer v1.3.0.
                                        • tt_suT
                                          tt_su
                                          @duanekemp said:
                                          Is there a possibility that Drop Components by Bounds may not be working in SU2015?
                                          It's working. If you have problems, please post a sample model.
                                          • duanekempD
                                            duanekemp
                                            Duane Kemp
                                            Kemp Productions
                                            Puidoux, Switzerland
                                            Gallery:
                                            https://duanekemp.artstation.com/
                                            • 3 / 3
