    Endpoint jumps to another endpoint in an arc
    7 Posts 4 Posters 373 Views 4 Watching
      dallard2
      When rendering smaller scale models and using a curve or arc, the straight line will snap to one of the other endpoints in the arc instead of staying on the original endpoint that I started on. Not sure how to stop this from happening.
      I've added some pics to show you what it's doing. The first Pic 1 is of a quarter circle having a radius of 0.05 and has just 12 segments. Pic 2 is showing after I've drawn the line from the bottom right endpoint straight up the blue axis. After releasing the mouse button the bottom of the line snaps to some other endpoint in the arc. : ( Now the line isn't perfectly straight with the blue axis.
      I've tried reinstalling sketchup but that doesn't work. I don't remember Pro 2013 having this problem.
      I'm using Window 7 with more than enough RAM and hard drive space. I've tried turning off the Hardware Acceleration as well but no change.
      Does anyone know why this is happening?
      I have drawn it larger by a factor of 10 and then scaling it down, which seems to work, but I shouldn't have to do that.
      • BoxB Offline
        You are attempting to work at too small a scale.
        Sketchup will not recognise points that are too close together and will therefore ignore them.
          dallard2
          That's too bad but it seems that it should be accurate up to 6 decimal places over since it can be chosen in 'Model Info' 'Units' and 'Length Units'.
          Is your statement something that's verified with Trimble?
            I don't know what you mean by "verified with Trimble" but this is well known among experienced SketchUp users. It's been that way since at least V3.
            • cottyC Offline
              cotty
              The units in the model info window do change the display (e.g. in the VCB) but don't have an influence on the small geometry problem.
              my SketchUp gallery
                dallard2
                Thanks for the heads-up everyone.
                • BoxB Offline
                  If you want to read a few more posts related to the subject, go to the advanced search feature, type Coincident as the keyword and Tig as the author. This should give you a couple of pages of posts talking about the limitations of small geometry in Sketchup.
