    Dumb Quetsion - How to remove a Position Camera
    4 Posts 2 Posters 1.3k Views 2 Watching
    • ntxdaveN Offline
      ntxdave
      I was doing a little experimenting and I clicked on the Position Camera. Now it "clips" the view when I orbit the view. How do I remove the "Position Camera"? I tried setting it to 0 but that did not accomplish what I want. I tried looking at the Model Info but did not see anything there. 😳
      Press F1...thank me later
      • ely862meE Offline
        ely862me
        CTRL+SHIFT+E ? Perhaps you are inside the geometry.
        Otherwise what have you set to 0 ? By any means the Field of view? Which needs to be 35...
        Elisei (sketchupper)
        Come and See EliseiDesign
        • ntxdaveN Offline
          ntxdave
          @ely862me said:
          CTRL+SHIFT+E ?
          **😍**Where does one find that in the documentation? I tried looking there but could not find it.
          • ely862meE Offline
            ely862me
            If you go to Window/Preferences/Shortcuts you have the possibility to assign any shortcuts to the actions/tools you need.
            Many are already assigned-if you go to Camera/Zoom Extents you will see that the Shortcut is already assigned by default.
            I would advice you now, to go trough every menu(File/Edit/View/Camera...) and I bet you will find things you never knew. Also, use every action/tool from there so that you know what they do.. Of course some are unavailable because you need to have something selected or else..
            Take care !
