    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Curtain Wall
    5 Posts 4 Posters 1.3k Views 4 Watching
      mistereight
      Hi!
      I have this trouble, i try to create a Curtain Wall with the plugin latticizer or lattice-maker but in the corner i have some problem of connection.
      There is a way easy to model a structure with the corner is not 90ยฐ, because if the angle is different the structure don't create a correct connection between the 2 different part curtain wall. ๐Ÿ˜ž
      Thanks.... ๐Ÿ˜‰
      structure of the building
      the kind of Curtain Wall
      the problem in the corner
      • yorik1984Y Offline
        yorik1984
        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=58694
          rv1974
          For the cases (rectangular profiles) you'd need 4 free plugins:
          1. windowizer 3 ( frame and glass offset set to zero)
          2. select by material
          3. remove coplanar faces
          4. Fredo's JPP.
          @yorik: may be I'm wrong, but the details (corners\joints) your protege generates are far from being perfect
            mistereight
            Thanks a lot! I will try today....this is the experiment make piece by piece the corner.....
              penumbra
              Why not use TIG's lattice maker?
