Curtain Wall
Hi!
I have this trouble, i try to create a Curtain Wall with the plugin latticizer or lattice-maker but in the corner i have some problem of connection.
There is a way easy to model a structure with the corner is not 90°, because if the angle is different the structure don't create a correct connection between the 2 different part curtain wall.
Thanks....
For the cases (rectangular profiles) you'd need 4 free plugins:
- windowizer 3 ( frame and glass offset set to zero)
- select by material
- remove coplanar faces
- Fredo's JPP.
@yorik: may be I'm wrong, but the details (corners\joints) your protege generates are far from being perfect
Thanks a lot! I will try today....this is the experiment make piece by piece the corner.....
Why not use TIG's lattice maker?
