    Applying texture to complex structures!
    6 Posts 3 Posters 447 Views 3 Watching
      Trzaskowski
      Hi!
      I have a question, how to place a seamless texture on models like this:
      I tried making my texture projected, but it was starched in many places.
      Thank you in advance πŸ˜„
      • cottyC Offline
        cotty
        I don't see your image. You know that you are able to attach an image to your post? (External image sources are mostly very slow!)
        my SketchUp gallery
          Trzaskowski
          Just click on image icon to enlarge the image.
            ...I tried making my texture projected, but it was starched in many places.
            I'm not sure what you mean by "starched" but perhaps you could upload the SKP file including the texture image.
            You should be able to apply the texture properly with it being set to Projected.
            I did this as a quick example. I applied the texture to a flat face, set it to Projected and then sampled it and applied it to the terrain mesh.
              Trzaskowski
              When there is more than 90Β° difference between faces, projected texture looks stretched.
              http://s29.postimg.org/6fjm5xk5x/st_1.png
              http://s23.postimg.org/j4gj4vwx7/st_1.png
              How to fix it?
                Of course it'll look stretched then if you have it set to Projected. It's doing what you're telling it to do. But that's not the same as your original image and situation, though. πŸ˜’
                Don't make the material projected and it works just fine.
