    WASD Plugin for SketchUp 2013
    4 Posts 3 Posters 949 Views 3 Watching
    • F Offline
      Florescu
      Hello!
      I was wondering if there is any sketchup plugin that enables WASD navigation for a better handling of the model.
      A good advice will help me a lot.
      Thank you
      • BoxB Offline
        You could try FPS Nav http://sketchucation.com/forums/viewtopic.php?p=350133#p350133
        You will need to change some of the default keyboard shortcuts for it to work properly.
          Anton_S
          On Windows, you could use AMS Library for that.
          require 'ams_Lib/core.rb'
          AMS;;Lib.require_all
          class MyTool
            def activate
              # Activate hook procedure.
              AMS;;InputProc.select_tool(self, true, false, false)
            def deactivate
              # Make sure we deactivate hook procedure.
              AMS;;InputProc.deselect_tool(self)
            def hk_onKeyDown(key, val)
              # Process message here...
              puts key
              # Return 1 to prevent key from interfering with SU window procedure.
              # Pass any other value (0 preferred) to leave the key alone.
              # In this case we return 1 for w, s, a, d messages, and 0 for the rest.
              %(w s a d).include?(key) ? 1 ; 0
            def hk_onKeyExtended(key, val)
            def hk_onKeyUp(key, val)
          end # class MyTool
          unless file_loaded?(__FILE__)
            item = menu.add_item('My WSAD Tool'){
              Sketchup.active_model.select_tool MyTool.new
          You can't use AMS Library for any other platform than Windows, as AMS Library uses MSFT Windows API to achieve such stuff.
          • F Offline
            Florescu
            Thank you very much. I'll try both options.
