    Place Camera
    3 Posts 2 Posters 327 Views 2 Watching
      apeavoy
      Wondering if you can help.
      When I place a camera in my model (to generate a perspective view), the model zooms out to such an extent that I can't see the buildings. It does not appear to be and issue with the eye level or the depth of field as I can set these correctly yet still nothing shows up.
        It would be a lot easier to identify the problem if we could see the model. When you write, "place a camera" are you referring to using Zoom Extents? It sounds like you have some sort of stray geometry located a long way from the rest of the model. That stray could be only a tiny little line segment and difficult to see.
        As for depth of field, that is fixed at infinite. You can adjust eye height and you can adjust angle of view.
        Posting the SKP file would make it easiest to determine exactly what is going on.
          apeavoy
          YES! It was stray geometry so thanks. Easily sorted.
          A.
