    Sketchup Crash Webdialog
    17 Posts 5 Posters 1.9k Views 5 Watching
    • H
      Hooch
      @tt_su said:
      @hooch said:
      I've now sended a bugsplat with a short description and the link to this forum-topic
      What did the description include? What can I search for to find it?
      "http://sketchucation.com/forums/viewtopic.php?f=180&t=58598" should be included, i've copied this link inside the description window
      • tt_suT
        tt_su
        Hm. The crash happens when some memory is freed. I need to pass this over to the QA team to see if they can reproduce on a test machine.
        • Chris FullmerC
          I've been trying to reproduce this, and so far no luck. I'm on Win 7, IE 9, SU 2014. Running this from the ruby console:
          dlg = UI::WebDialog.new("Titel", true, "VS_REG", 739, 641, 150, 150, true); dlg.set_url "http://github.com" dlg.show
          Any other hints or ideas on how to reproduce it?
          I have thing you could try to do, to see if it helps. Go to:
          C:\Users<user>\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp
          and delete the session.dat and the cookiejar.xml file. Probably best to save them though, so move them somewhere like your desktop to keep them safe. That way, if we determine it is something in one of those files, we will still have them around to look into.
          Anyhow, try removing those files and then try your script again and see if it works.
          • H
            Hooch
            I've sended you a private message with a link and login where you can (hopefully) reproduce the bugsplat. I think its a problem with the bunch of java script used on this side, but nevertheless should Sketchup not bugsplat ..
            I've tried also to move the files away (session.dat wasn't there), but it didn't help.
              As I understand it SketchUp v2014 makes a cookiejar.xml, while the session.dat file is made in SketchUp pre-v2014 ?
              • Chris FullmerC
                I <believe> I have seen the 2 files co-exist in the same folder at the same time. I believe you are correct that the cookiejar.xml is only for 2014. But I think 2014 might also make use of the session.dat. I'm not sure though, I should ask Tyler how that was implemented.
                  I've never seen it πŸ˜• But that doesn't ensure it's never used πŸ˜’
                  • H
                    Hooch
                    Chris, could you reproduce the bugsplat with the sended website in the private message? If you can't, than I also have a video showing the crash, but I think it's more helpful for you if you can reproduce it by yourself.
                    Greetings
                    Alex
                    • H
                      Hooch
                      Hey ho,
                      are there any news for this topic? we could reproduce the error on IE 11 in the mean time .. i think there are some random java script errors on the website, but nevertheless this shouldn't cause SketchUp to a bug splat ..
                      Greetings
                      • Chris FullmerC
                        Hi Hooch, I responded to your private message a few days ago. I was able to reproduce this, but I am unable to determine what the crash is. I'll log it in our system for an engineer to look at.
                        • L
                          lionk
                          the crash does exist.
                          what is the solution?
