Housebuilder
Hi- Have been trying to get housebuilder plugin installed in SU 2014 pro windows for a while now w/out much success. The most I have been able to et is the basic program w/out toolbar and the program does not have doors & windows. Please help - I am definitely not literate on plugins/extensions.
Jim
It sounds like an installation error. Which version did you install and how did you go about installing it?
Hi Dave, you have tried to help me with this before(thank you) - Installed s. hurlbut version from library depot. Downloaded into my downloads - changed from zip file to .rbz - in SU went to windows /preferences and install extension. HB does not show up in extensions and in view does not show up in toolbars?
I thought we tried this before.
I have not been able to get it to work...I believe I did it exactly as you described?
Did you get my PM?
Thank you Dave, it worked perfectly. Could it be the previous versions I tried were not compatible with new windows/sketchup?
Could be. Or maybe you weren't holding your tongue right when you installed the previous version.
I'm glad it works now, though.
Thanks again - much appreciated - will remember to Jordan the tongue on the next one...
