    3D printing Tips and tricks needed for model
    11 Posts 4 Posters 9.3k Views 4 Watching
    • soloS Offline
      I need to get an organic model ready for printing, it's heavy, bloated and has lots on tiny holes.
      I have SuSolid but this model may need a 3rd party help.
      Anyone got an idea of how to get this solid and ready?
      • dukejazzD Offline
        dukejazz
        Simplify3D Software Now Available for German RepRap 3D printers | ENGINEERING.com
        "The software, especially the slicing functionality, has a big influence on the print quality. Simplify3D"
        can yout model be slice then simplefied
        do you have jpg or skp of what your working on
        it hard to see the holses in your model
        To work for a solution. need more info
        • soloS Offline
          The problem is I cannot show or share the model as it's a prototype for a company. I did the model a while back and printing it was never mentioned then so I modeled for patent purposes only, now they need to print it and the model is not water tight.
          Is there a software out there that can skin a model? create a solid model from a crappy one?
          • dukejazzD Offline
            dukejazz
            This is the same problem in many fields like space and the medical field, its hard to clean a course surface, to get a smooth surface the stacking surface layers can't be greater then 45 degree from vertical.
            Also if you can model it by slicing them many times and then simplified. This will make it smoother exterior
            I feel interior cutouts of any shape should be a unbroken spear, it ok to elongate it vertical but not horizontal when you test the layer center of volume make sure it moments is balance so it doesn't fall over
            If you use object is used in multiple direction some stiffing may be needed and use a perfect spear, to cut-out from interior solid objects from counterpoint
            Rule of thumb:
            Stable object is a pyramidal shape that wont fall over in earth quake, right!
            Strong inter shape think of romans arches or domes
            Quick and dirty way of making it water tight:
            Print haft then spray water sealent on the inside and then coat the outside with a coat of your materials or aniode meteals, or for plasic spray acetone after printing object. (fit hafts togather with a glue bound with wegets)
            You can use a 3d pen to fix defects
            Also beteen the thin skin inside and outside walls is a 3d skin mesh may be used:( make it water tight)
            to make 3d skin inner spear mesh use the joint push-pull tool-Fredo6 then interface with model trim out side away.
            • olisheaO Offline
              olishea
              Meshlab and Netfabb
              oli
              • olisheaO Offline
                olishea
                (www.shapeways.com)
                oli
                  d12dozr
                  There is also an online version of Netfabb that is much more powerful than the downloadable version. Simply upload your model as an .STL file (exporter available here), and in a few minutes you can download a cleaned, and usually watertight model ready for 3D Printing.
                  That service has not failed me yet, and their terms of service say they will treat your model with confidentiality. It may fail if the model has large parts missing, as the fixing is all automatic, but if the model just has lots of small errors you should be just fine.
                  http://goo.gl/f7ooYh
                  • soloS Offline
                    That online solution was the monkeys balls, worked like a charm.
                    Thanks you and everyone above.
                    • olisheaO Offline
                      olishea
                      Glad to hear it's sorted! 👍
                      Marcus told me about that netfabb a while back and it's been great, although I didn't realise there was a difference between online version and downloadable one. 👍
                      When/if you get permission to disclose the project, why not share some images of the printed model? Good luck and all the best Pete.
                      oli
                      • dukejazzD Offline
                        dukejazz
                        I just found this today
                        Just a tip
                        freeform is a free program
                        Just bring your object to freeform and then you transfer to Sculpteo then it has a auto 3d print function with some menus that will 3d print then by a 3d print service and then auto mailed them back to you. all objects will be analyze before the service prints them.
                        So no junk gets printed.
                        I don't think its auto fix skins to every model? just those made in freeform
                        I need to play with freeform soon
                        Decoding 3D Printing: Sculpteo @ Autodesk | Edwin Abarca
                        https://www.leapmotion.com/blog/decoding-3d-printing-sculpteo-autodesk/
                        %(#008000)["How we think about everyday objects is changing with accessible 3D printing, and new tools are emerging to make it easier to design and create just about anything you can imagine. Sculpteo and the Autodesk Gallery recently hosted a “Decoding 3D Printing” workshop to help hobbyists and professionals get up to speed in an afternoon
                        The idea behind Freeform is simple – it takes days to learn a CAD program just to make a simple object that you could make in a few seconds with clay. In turn, Sculpteo opens up 3D printing to everyone, so you can make anything from a figurine to an artificial limb after designing it on your computer. Naturally, this gets us excited for what the future has in store. As always, hope to see you at the next meetup, and keep dreaming!"]
                        https://www.leapmotion.com/wp-content/uploads/2014/01/3d-printed-freeform-cup.jpg
                          d12dozr
                          Excellent! Glad to hear that, Pete 👍
