[Plugin] s4u_toComponents
Thanks pep75!
thanks biggest fan! ... -
I AM! Yes! Uhmm..but one question, I've installed the plugin but I don't get the extended toolbar like you..I still have the normal 5 icons..is this correct?
Thank you! -
You try delete old version in folder plugin sketchup
YES it Works! Now I've the 'Immense' toolbar! Thanks again!!!!
Finaly you make it free / Donate ?
Use it here in this little thing
It's free for super tester Pillou!
Magic of the auto similarity no uniform!
Additional,It work correct for all sublevel of Component,keep hierarchy.
Very cool!
And when you have triangular face use
Quadrilateralizater by TIGPS For the inverse
by Renderiza Face Split triangulate all faces! -
Good combination!
Made with Extrude Tools by TIG
Weld Curves : Recurve by Digssey
Selection Toys by Thomthom
Make 2 Arcs Circles + 1 profile
(option Quadrilaters)
Trick is Select only Soft Edges then Kill them -
I just tried Faces to Components with SU pro's dynamic components and it works
Here is the fisrt test : the component "hight" is function of its Z position and its Y rotation (LenZ=20+RotY-Z/10)
The only rule is EVERYTHING must be in a "master" component to have acces to the Dynamic Component Redraw command (on this "master" component) to update all components.
Great plugin!
thank you. -
hi dear
15 dollars !!!
what do you think about us ???
do you think we are rockefeller in new york city !!! -
if you can't ,you use this free plugin
http://sketchucation.com/pluginstore?pln=clf_shape_bender_v055.
it's like my plugin. -
@gfgfgfgfgf10 said:
hi dear
15 dollars !!!
do you think we are rockefeller in new york city !!!you do not have to be rockefeller to buy this plugin...
better spend $ 15 rather than i have to make this plugin... -
Hello,
A member of thea render's forum told me to post my work to explain how great is your plugin !!!
I have created this for my spare time last weekend. i used only "line to component" tool : so easy !!!
it's perfect... quite perfect, because in my case, is it possible to freeze scale of the components? if yes, how is it possible? if,no, no problemo, and congrat, your plug is still a must
Yohdubato! nice model!
You can reset scale component by 2 plugins
s4u_Scaletool ,free
http://sketchucation.com/pluginstore?pln=s4u_scaletool
or
s4u Transformer,20$ (selectable origin components)
http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=59210
Cheers! -
thanks for your links ; those plugins are great too!!!
i will try them++
