    [Plugin] s4u_toComponents
    89 Posts 26 Posters 104.2k Views 26 Watching
    • jolranJ Offline
      jolran
      like your plugin,i will study it,
      Thanks, but current release is only linehatches orginating from TIG's mentoring.
      It probably won't help you.
      I havent released tiling for Components onto surface yet since I thought it was to slow when scaling non-uniformally.
      Aligning a Component to the center of a Square face and scaling it to fit is relatively easy. But not when face is tapered. Mostly common in spheric objects and bulges.
      As you most certainly have discovered there is no API-method for tapering.
      So that means when a face is not paralleogram(?) one has to go in and alter each tiled Component individually == make Component uniq.
      Maybe you have found some nice solution for this, I don't know.
      In my case I came up with a linesweep algoritm that scanned the face vertices and scaled the Component to be tapered. As mentioned going in doing this sweep and translating Components vertices X n.times is gonna be slow nomatterwhat.
      If this could be taken externally in C perhaps would help, but still won't be faster than API methods. I reckon.. Kind of a Catch 22.
      If looking on the positive side of things, since I'm starting to sound a bit negative.
      It's better to sit and wait a couple of minutes than putting the Components there manually πŸ˜„ As long as Sketchup doesent freezes πŸ‘Š
      Anyway, will be interesting to see what you come up with. πŸŽ‰
      • I Offline
        ivreich
        Any chance this plugin can be designed to work with thomthom's Quads definition, so we can finally get a proper panelisation tool?
        Currently only works with planar surfaces. It would be awesome if it would work with non-planar quads and perhaps allow thickness to be defined.
        Joel
        • hdpvH Offline
          hdpv
          Jolran!
          paralleogram face,I use API "entities.transform_by_vectors sub_entities, vector_array" move vertices in component.Length vector is ratio x,y of vertex.
          Joel!
          I would like that works with non-planar surfaces ,take time to work πŸ˜„
          Suforyou
          http://www.sketchupforyou.com
          • pep75P Offline
            pep75
            I THINK THIS IS ONE OF THE MOST REVOLUTIONARY PLUGIN IN YEARS!!!!
            I'm your biggest fan! πŸ˜„)!
            • pep75P Offline
              pep75
              I just have sent you a donation!
              • hdpvH Offline
                hdpv
                Thank you very much for your 10 cups of Vietnamese coffee. πŸ˜„
                Suforyou
                  janclintongabriel
                  can you help me how to download and install this? im having a hard time i really need this great plugin πŸ˜„
                  • hdpvH Offline
                    hdpv
                    install extention:
                    http://sketchucation.com/resources/tutorials/37-beginner/108-installing-sketchup-plugins
                    download:
                    http://sketchucation.com/resources/pluginstore?pln=s4u_toComponents_v3.0.0
                    or
                    http://extensions.sketchup.com/en/content/s4u-components
                    Suforyou
                      janclintongabriel
                      thank you very much for the help sir:) great plugin a really big help
                        Very cool Plugin! 😎
                        I have seen on your video that V4 is existing! β˜€
                        But seems not updated here ?
                        [bbvideo 640,480]http://www.youtube.com/watch?v=Bld61FlL4vw
                        [/bbvideo]
                        • hdpvH Offline
                          hdpv
                          Hi Pilou!
                          This is S4u-toComponents v4.0.7
                          I will update on this July 04.
                          It's cost 10$ πŸ˜„
                          Suforyou
                            thx for the info! πŸ˜„
                            • hdpvH Offline
                              hdpv
                              It's ready.
                              I hope you enjoy my plugin. πŸ˜„
                              Suforyou
                              • pep75P Offline
                                pep75
                                It's such a brilliant plugin! I love these kind of "modifiers"...superb...Thanks again!
                                • hdpvH Offline
                                  hdpv
                                  Thanks pep75!
                                  thanks biggest fan! ...πŸ˜‰
                                  Suforyou
                                  • pep75P Offline
                                    pep75
                                    I AM! Yes! Uhmm..but one question, I've installed the plugin but I don't get the extended toolbar like you..I still have the normal 5 icons..is this correct?
                                    Thank you!
                                    • hdpvH Offline
                                      hdpv
                                      You try delete old version in folder plugin sketchup
                                      Suforyou
                                      • pep75P Offline
                                        pep75
                                        YES it Works! Now I've the 'Immense' toolbar! πŸ˜‰ Thanks again!!!!
                                          Finaly you make it free / Donate ?
                                          Use it here in this little thing πŸ˜‰
                                          • hdpvH Offline
                                            hdpv
                                            It's free for super tester Pillou! πŸ˜„
                                            Suforyou
                                            • 3 / 5
