    Changing sheet size..??
    layout
    3 Posts 3 Posters 717 Views 3 Watching
    • Clayton49C Offline
      Clayton49
      To all,
      CHANGING SHEET SIZE
      If you have an existing project in LAYOUT, say all A2 size sheets, can you later go back to this project & change the sheet size to say A1 & retain your work...??
      Also, can you have one project, with various sheet sizes....??
      Over & out,
      Clayton.
      Over & out,
      Clayton.
      %(#008000)[Trotman & Taylor
      Architectural Consultants]
        dedmin
        Yes, but the content wont scale automatically.
        All pages are the same size - as far as I know.
          You can change the paper size under File>Document SetUp>Paper. As dedmin alludes, the content won't get scaled with the paper size change. If you go from A2 to A1, you'll find the content is stuffed into the upper left corner still fitting into the space of the A2 sheet. You can only set one sheet size per LayOut file. If you need more than one sheet size you'll need to split it into more than one LO project. You can combine PDFs if needed in Acrobat or some other applications.
