[Plugin] s4u_toComponents
can you help me how to download and install this? im having a hard time i really need this great plugin
thank you very much for the help sir:) great plugin a really big help
Very cool Plugin!
I have seen on your video that V4 is existing!
But seems not updated here ?[bbvideo 640,480]http://www.youtube.com/watch?v=Bld61FlL4vw
[/bbvideo] -
Hi Pilou!
This is S4u-toComponents v4.0.7
I will update on this July 04.
It's cost 10$ -
thx for the info!
It's ready.
I hope you enjoy my plugin. -
It's such a brilliant plugin! I love these kind of "modifiers"...superb...Thanks again!
Thanks pep75!
thanks biggest fan! ... -
I AM! Yes! Uhmm..but one question, I've installed the plugin but I don't get the extended toolbar like you..I still have the normal 5 icons..is this correct?
Thank you! -
You try delete old version in folder plugin sketchup
YES it Works! Now I've the 'Immense' toolbar! Thanks again!!!!
Finaly you make it free / Donate ?
Use it here in this little thing
It's free for super tester Pillou!
Magic of the auto similarity no uniform!
Additional,It work correct for all sublevel of Component,keep hierarchy.
Very cool!
And when you have triangular face use
Quadrilateralizater by TIGPS For the inverse
by Renderiza Face Split triangulate all faces! -
Good combination!
Made with Extrude Tools by TIG
Weld Curves : Recurve by Digssey
Selection Toys by Thomthom
Make 2 Arcs Circles + 1 profile
(option Quadrilaters)
Trick is Select only Soft Edges then Kill them -
I just tried Faces to Components with SU pro's dynamic components and it works
Here is the fisrt test : the component "hight" is function of its Z position and its Y rotation (LenZ=20+RotY-Z/10)
The only rule is EVERYTHING must be in a "master" component to have acces to the Dynamic Component Redraw command (on this "master" component) to update all components.
