    [Scpapbooks]Fixture for Layout 3 and 2013
    layout
    12 Posts 7 Posters 7.0k Views 7 Watching
    • yorik1984Y Offline
      yorik1984
      I want intruduce my scrapbook for Layout 2013 and Layout 3.
      It most popular fixture. Archive include files of version for Layout 2013 and Layout 3, fonts, preview in PNG and PDF, description.
      P.S. Many thanks to Pingpink for helping in translation
      [DESCRIPTION]
      Hardware kit for using in LayOut 2013 and LayOut 3.
      Brief description of the set:
      • Anchor "Hilti";
      • Dowel Quick mounting diameter of 6 mm and 8 mm ;
      • Anchors for fixing insulation ;
      • Bolts, Nuts (normal , high, low , self-stopped , cap ), M6, M8 , M10, M12 , M16 , M20 , M24 ;
      • Washers for the above bolts and nuts ( flat, small, normal ,extra-large );
      • Self-drilling and self-tapping screws with a diameter of 3.5-6.3 mm ( with round , oval , flat ,
        hexagon heads with washers and without washers) .
      • Blind Rivet ( and countersunk flat head ) with a diameter of 2.4-6.4 mm .
        Detailed specification of products is given below for each file.
        [USING]
        For items which are outside the range of values, the overall size is according to the need to
        change these values only. Red lines denote the current size of the component.
        To change the dimensions, users need to log into the group and subgroup-extreme move in
        the right direction according to size. Average subgroup "stretch" to connect to the extreme.
        Depending on the type of component, specified subgroup sizes may be different.
        In general, there always have three subgroups.
        It is also possible to use two kinds of external components:
      • Just out of the lines ;
      • Filled circuit ( any color is white by default ) .
        “Change in appearance” produced by enabling or disabling the button "Fill" in the dialog
        box tray of "Shape style". You can either apply the "outside" and "inside" groups for its parts by
        selecting the loop variable part.
        Note : Ability to use fill in the components of the anchors "Hilti" is missing. For this kind of type of
        fasteners used appearance "Just out of lines."
        The different appearances of two types, you can see an image file from "Bolts.png".
        [List of files with description]
        [Fixrure_Anchors_Hilti]
        Anchors "Hilti"
      • HST-R(M8-10, M8-30, M10-10, M10-30, M10-50, M12-20, M12-50, M16-25, M16-50, M16-140,
        M20-30, M24-30);
      • HST(M8-10, M8-30, M8-50, M10-10, M10-30, M10-50, M12-20, M12-50, M12-90, M12-120, M12-
        140, M12-160, M16-25, M16-50, M16-100, M16-140, M16-180, M20-30, M20-60, M20-130, M24-30,
        M24-60);
      • HRD-H 10x(80, 100, 120, 140, 160, 180, 200);
      • HRD-C 10x(80, 100, 120, 140, 160, 180, 200, 230, 270, 310);
      • HT 10/(72, 92, 112, 132, 152, 182, 202).
        [Fixture_Anchors_Quick_Fixing]
        Plastic quick-fixing anchors:
      • 6x40(60, 80);
      • 8x60(80, 100, 120, 140).
        Metal dowel quick installation:
      • 6x40(70).
        [Fixture_Anchors_Rockwool]
        Anchor for installation of insulation
      • 10/60-80(90, 100, 110, 120, 140, 160, 180, 200, 220, 260, 300);
      • 10/90-80(90, 100, 110, 120, 140, 160, 180, 200, 220, 260, 300);
      • Metal washers diameter of 60-80 mm
        [Fixture_Bolts_ISO 4014 (GOST 7805-70_Grade A)]
        ISO 4014 (GOST 7805-70) - Hexagon head bolts. Product grades A and B M6, M8, M10, M12,
        M16, M20, M24.
        Dimensions are according to the standard. The list contains no length is not recommend to
        the advised length standard.
        [Fixture_Nuts]
        Nuts with metric thread of M6, M8, M10, M12, M16, M20, M24:
      • ISO 4032 (GOST 5297-70) - Hexagon regular nuts (style 1). Product grades A and B;
      • ISO 4033 (GOST 15524-70) - Hexagon high nuts (style 2). Product grades A and B;
      • ISO 4035 (GOST 5929-70) - Hexagon thin nuts chamfered (style 0). Product grades A and B;
      • ISO 7040 (GOST P 50273-92) - Prevailing torque type hexagon regular nuts
        (with non-metallic insert). Property classes 5, 8 and 10;
      • ISO 7042 (GOST P 50273-92) - Prevailing torque type all-metal hexagon high nuts. Property
        classes 5, 8, 10 and 12;
      • DIN 1587 (GOST 11860-85)- Hexagon domed cap nuts.
        [Fixture_Washers]
        Flat washers are designed for bolts and nuts M6, M8, M10, M12, M16, M20, M24:
      • ISO 7091 (GOST 11371-78) - Plain washers. Normal series. Product grade C;
      • ISO 7092 (GOST 10450-78) - Plain washers. Small series. Product grade A;
      • ISO 7093-1(2) (GOST 6958-78) - Plain washers. Large series. Part 1: Product grade A and C;
      • ISO 7094 R (GOST 28848-90) - Flat washer for wood constructions, type R;
      • ISO 7094 V - Flat washer for wood constructions, typeV(square hole).
        [Fixture_Rivets]
        Blind Rivet. The standard provides a variety of body materials and the core of the same dimensions.
      • ISO 15977(Al/St), ISO 15979(St/St), ISO 15981(Al/Al), ISO 15983(A2/A2) - Open end blind rivets
        with break pull mandrel and protruding head. Diameter : 2.4, 3, 3.2, 4, 4.8, 5, 6, 6.4 mm;
      • ISO 15978(Al/St), ISO 15980(St/St), ISO 15982(Al/Al), ISO 15984(A2/A2) - Open end blind rivets
        with break pull mandrel and countersunk head. Diameter : 3, 3.2, 4, 4.8, 5 mm.
        [Fixture_Drilling_screws]
        Self-drilling and self-tapping screws with a diameter of 3.5- 6.3 mm. Length from 9.5-6.5 mm.
      • ISO 15480 - Hexagon washer head drilling screws with tapping screw thread;
      • ISO 15481 - Cross recessed pan head drilling screws with tapping screw thread;
      • ISO 15482 - Cross recessed countersunk head drilling screws with tapping screw thread;
      • ISO 15483 - Cross recessed raised countersunk head drilling screws with tapping screw thread;
      • ISO 7049 - Cross-recessed pan head tapping screws;
      • ISO 7050 - Cross-recessed countersunk (flat) head tapping screws.
      Install_Fixture.zip
      PREVIEW_FIXTURE.zip
        gbing
        Hello Yurij,
        thank you so much for sharing!!
        Great job. 👍
        Giovanni
        • JasonWDJ Offline
          JasonWD
          Thanks from me too... it would have taken me ages to find then import all those fixings to layout.
          I owe you a Mernaya!
          SketchUp, Thea Render, Vectorworks PC and Mac - Full LayOut workflow Concept>Production
          • JQLJ Offline
            JQL
            Unbelievable work, very handy for many of us, I'm sure! Thanks!
            www.casca.pt
            Visit us on facebook!
            • KrisidiousK Offline
              Krisidious
              Looks great, thanks so much. FYI; In America these would be called fasteners or screws, nuts and bolts...
              By: Kristoff Rand
              • JasonWDJ Offline
                JasonWD
                We call them fixings in the UK... I actually found them by googling "Fixings Layout" and came full circle back here.
                  Krisidious
                  In America "Fixings" go on top of a potato and architecturally speaking, "Fixtures" are usually sinks, toilets, other plumbing items and also lighting fixtures...
                  By: Kristoff Rand
                  • JasonWDJ Offline
                    JasonWD
                    Same with fixtures here; the potato thing though...
                    shakes head at Americans patronisingly
                      Krisidious
                      By: Kristoff Rand
                        yorik1984
                        Lost in Translation 💚
                        Can somebody to help translate correctly?
                          Charlie__V
                          !["Fixins" on Loaded Baked Potato](/uploads/imported_attachments/VSFf_loadedbakedpotato.jpg ""Fixins" on Loaded Baked Potato")
                            BvN
                            Hi, am very new to Layout - what do I do with the download files please - and how use in Layout
                            thanx
