    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      Q 1 version 2.1.0
      Q 2 Mac users are not always so happy than PC Users πŸ˜‰
      I can't answer for that, I am a PC User πŸ˜„
      Q 3 Same than Q2 πŸ˜‰
      Q 4 Some years that I don't use it! 😳 Some cool interface Now! πŸ‘
      But really no problem! 😎
      I have made absolutly no regulates! πŸ€“
      Select a surface then use the Green Dialog Box
      With this Dialog Box you can use only Component by Component!
      http://s6.postimg.org/e93quoa1d/fur.jpg
      Q 5 Sorry no problem for me with the Crowd dialog box! πŸ’š
      I believe that you must use a PC! πŸ˜‰
      http://s6.postimg.org/okg3nc1qp/fur1.jpg
        But from your left image seems you have not "Check" your 2 components ! ?
        • McGyverM Offline
          McGyver
          That was just for the screen shot, I took pictures of each menu and put them together in one image using photoshop... I have tried checking the boxes, there is no reaction from the plugin when you click "Make Crowd"
          [Visit My ShareCG Freebie Gallery](http://www.ShareCG.com/pf/full_uploads.php?pf_user_name)
          • McGyverM Offline
            McGyver
            Okay... Something was amiss... I turned of the computer and restarted it and now it works... it makes crowds.
            I think I know what the problem was... sometimes my computer acts a little wonky after using certain programs at the same time... so to get it back to normal, I'll shut it down for a few minutes... which I just did... now I see the tool palette buttons too, which were not showing up in the preferences...
            Also one other thing... I guess I failed to purge the document I was testing fur with... leaf1 was a component I made to test the crowd feature, but I deleted it and made a pink box instead... which did not appear a choice...
            The weird thing is leaf1 one was actually the file name, not the component name... (TestLeaf)... I don't know why it chose the file name over the component name... So when I saw "leaf1" I thought it was some built in component...
            Still, if it had populated the surface I would have seen it was my component.
            Some of the controls are slightly different for Mac (still no slider controls, but no big deal), but the crowd feature DOES work...
            So thanks again Pilou, it does now work more or less exactly as you showed in your "How to" images (which I thank you very much for going through the trouble of making!).
            Have a great day!
            • McGyverM Offline
              McGyver
              Hello Pilou.
              Thank you for the link to TreeMaker, I have been using it a lot lately, but I wanted to be able to populate a small terrain with my own models (or simple billboard components)... what I was actually trying to do, was make specific weeds for an overgrown area... TreeMaker is very good, but the template models are too... "pretty" for weeds and I do not really know how to add my own models to the list (if that is even possible)... so I decided to try Fur which sort seems to work like Component Spray, but with more random distribution.
              I used the other link you provided and downloaded V 2.1.0... I see now that I skimmed past the the "Download Here" link at the top and went straight to the bottom where the updates usually used to be... I keep doing that with older plugins, I forget that the links to the newer versions at the PluginStore are often at the top now, so thank you again for the link.
              EDITED OUT PREVIOUS TEXT AS I NOW HAVE THE PLUGIN RUNNING
              I think that the dialog boxes are different for Windows and Mac.
              Once again, thank you Pilou for the links and info!
                Have happy discovery of this amazing plugin! β˜€
                • McGyverM Offline
                  McGyver
                  I will have lots of fun using this, thanks Pilou!
                  The billboards I made looked terrible when rendered in Poser, but the PNGs look okay in SketchUp... So, just in case anyone wants to use them for something in SketchUp, here are the smaller versions I used in SU... They are very simple... it was just for a test, so sorry if they look a little cartoon-like.
                  • OxerO Offline
                    Oxer
                    Hi McGyver, I have installed the last version 2.1.0 on Mac and the fur-web dialogues are showing correctly the sliders.
                    Web Dialogues
                    For me the Crowd never has worked on Mac, it creates always a group with little triangles.
                    Crowd on Mac
                    Mac OSX 10.9.3 & SU2014
                      Jorgensen
                      First thank you very much for this very nice plugin!
                      I'm trying to create a grassfield using the Make Crowd function, but I find the density to low.
                      What I do -
                      I select the face
                      Set the density to max (20)
                      Select my grass component
                      This generate some instances, but not enough to give the impression of a grassfield.
                      Is there a way to rise the density or do I do something wrong?
                      Thanks πŸ˜„
                        There is no Max! Or in any case more than 20! πŸ˜‰
                        Seems numbers of object = Density * 10 so be careful!
                          Jorgensen
                          hi pilou
                          it seems to make no difference if i select a density of 5 or 20, the polygons never get more than 10017.
                          i'm properbly do something wrong, but i don't know what πŸ˜•
                            Jorgensen
                            My fault - i set density to high.
                              amos_miers
                              Has anyone experienced the generation of the items heavily in some portions and light in others, following hard diagonal lines dividing the place? I cannot seem to apply the script evenly in most of my spaces. I am using 2014.
                                If they are visible : Cleanup by Thomthom : Merge Coplanar Faces
                                If they are invible, Enable Hidden Geometry : Selection Toys by Thomthom
                                Select Soft or Smooth Edges then kill them
                                • hajkardiH Offline
                                  hajkardi
                                  I have problem on slope terrain with plugin. I try to change all parameters but no luck?! Some parts of terrain is cover properly, but some have lack of grass. I download last version of plugin 2.1.0 and I have Sketch 2013 pro.
                                  http://i.imgur.com/k02tm7X.jpg
                                    Ayomidotun
                                    Thanks Bro!
                                      tak2hata
                                      Hi,haikardi.
                                      Sorry for my reply too late.
                                      I guess the problem is "MaxNumber(/Face)".
                                      Please set high value to "MaxNumber(/Face)".
                                      "MaxNumber(/Face)" is limit for creating too much fur.
                                      by TAK2HATA
                                      • soloS Offline
                                        I love this plugin, really helps me to distribute grass proxy's. I do have one request, sometimes even the lowest values are too much, I'd really like to distribute (make crowd) with .5, .2 values.
                                        Oh!v a distribution brush would also be most welcome.
                                        • jiminy-billy-bobJ Offline
                                          jiminy-billy-bob
                                          What do you mean by that?
                                          Something like Components Spray?
                                          • V Offline
                                            Vincy_PC
                                            how to install in skp 2014?
                                            • 32
                                            • 33
                                            • 2 / 33
