    Section cut lines disappearing on vector exports/renders
    3 Posts 3 Posters 1.5k Views 3 Watching
      robburton_uk
      I have 2D plan section scenes set up for clean hidden line vector plans that I export for 2D dwgs and import into Layout for architectural drawings. I have been running this work flow for a while with no issues, however, recently some random components do not render section cuts on vector exports (DWG+Layout). Raster exports are fine?
      The strange thing is a component with same geometry/layer will render cut in one place and not on another?
      I attached screen grab showing SkUp scene and Layout vector render....and pointers would be appreciated.
      • mitcorbM Offline
        mitcorb
        Hello:
        Your screen image does not appear.
        click the upload attachment tab in the reply editor page, browse, select, then add the file button.
          Where did you attach the screen grab?
          Is it possible the section cut is inside a group or component that doesn't contain the uncut components?
