    Moving a compo-instance by z
    2 Posts 2 Posters 269 Views 2 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi,
      i have a component-instance somewhere in space and i want to copy it in vertical direction.
      how can i say to the transformation, that the movement is only Z and in the position of the original component?
      (the position comes from a mouse-selection, so is not pre-calculated, but given...)
      the transformation allows to input a 3d point [0,0,height_delta],
      but i cannot retrieve the x,y of the original component ....
      my_component = group.to_component
            defn = zf_component.definition
      	#defn.name = "name"
      		for groupcopy in 1..my_amount
      		edge = model.entities.add_line([0,0,0],[0,0,@height*groupcopy])
      		vector = edge.start.position.vector_to(edge.end.position)
      		distance = edge.length
      		vector.length = distance
      		toppoint_1 = [0,0,@height*groupcopy]
      		nullpoint = [0,0,0]
      	        toppoint_2 = vector[1]
      	componentinstance =
      	entities.add_instance(defn, [ 0,0,0]) # ???? HOW TO DEFINE THE POSITION OF THE ORIGINAL COMPONENT-DEFINITION TO BECOME A COPY AT THE SAME POSITION ???
      	new_transformation = Geom;;Transformation.new([ 0,0,@height*groupcopy])
       	componentinstance.move! new_transformation
      thanx
      stan
        You have a component definition [ defn].
        You have an instance of it [ inst1].
        That instance has a transformation [ tr1=inst1.transformation].
        That transformation has an origin [ org=tr1.origin] - i.e. its 'insertion point'.
        You make a new transformation based on that:
        tr2=Geom::Transformation.new([org.x, org.y, org.z+z_increment])
        Where the ' z_increment' is the amount by which you want to move the copy upwards - either in inches or a Length.
        You add the copy thus:
        inst2=inst1.add_instance(defn, tr2)
