    Maxwell grass feature experiment
    14 Posts 8 Posters 3.4k Views 8 Watching
    • novenaN Offline
      novena
      Hi guys
      I was experimenting with the grass extension of Maxwell render standalone plugin for SketchUp, here come some results, to achieve the angle variation of the blades I used an angle map, rendered within SU with the free version of the Maxwell plugin
      best
      V
      http://hdzarkitektur.wordpress.com/
      • JQLJ Offline
        JQL
        Nice!
        www.casca.pt
        Visit us on facebook!
        • DanielD Offline
          Daniel
          those look incredible, novena.
          Makes me wish I had the time to try that software out.
          My avatar is an anachronism.
          • hellnbakH Offline
            hellnbak
            Really nice work. That last one, unfortunately, looks a lot like my front lawn πŸ˜’
            • novenaN Offline
              novena
              thanks a lot guys! I appreciate your comments...
              best
              V
              • utilerU Offline
                utiler
                very cool and soooo easy!!
                Just Curious...
                • ken28875K Offline
                  ken28875
                  This is awesome, Victor. Loving it. πŸ‘ πŸ‘
                  Best,
                  _KN
                  Follow Your Dreams.
                  • novenaN Offline
                    novena
                    Thanks utiler,
                    Yes it is soooo easy, with just a couple of clicks I got all those variations of the grass
                    Best,
                    _KN
                    Thanks Ken, I appreciate your comments
                    Best
                    V
                    • wychylylybymyW Offline
                      wychylylybymy
                      Nice! how long you were render it?
                      qb.carbonmade.com
                      https://www.facebook.com/qbwizualizacje
                      • novenaN Offline
                        novena
                        Thanks! It took about 15-20 min per image
                        Best
                        V
                        • RichardR Offline
                          Richard
                          Mate, I'm impressed!! Could you show us what you mean about an angle map?
                          I've really fallen behind with my Maxwell skills having neglected to upgrade for a bit, I really need to seeing this!
                          BUILTBRAND.COM.AU
                          • novenaN Offline
                            novena
                            Richard, thanks! Im glad you like it!
                            The angle maps is applied to the maxwell grass parameter 'initial angle', the map is an RGB map, where red, green and blue correspond to the axis X, Y, Z, that way the grass grows in the direction determined by the angle map.
                            The angle map I used is created using a photoshop action on a black and white image, the photoshop action can be downloaded here:
                            http://support.nextlimit.com/display/tuts/Grass+Tutorials
                            I have no access to my computer and files until next wednsday, then I can show you the angle map used
                            Best
                            V
                            • novenaN Offline
                              novena
                              Hi Richard!
                              sorry for the delay...
                              this is the anglemap I used for the experiment, I did 2 copies of the same map applying blur filter at different values in photoshop to generate more variants...
                              I attached 2 images to compare grass with and without anglemap, and a screen capture with the Maxwell grass parameters used...
                              best
                              V
                              anglemap
                              grass without anglemap
                              grass with anglemap
                              • RichardR Offline
                                Richard
                                Thanks for getting back to this mate!!! That's an impressive result!
                                Do you notice a distinct line if the angle map isn't seamless?
                                I've so got to update my softs. It's been a while!
                                BUILTBRAND.COM.AU
