    Kerkythea and Sketchup2014
    extensions
    26 Posts 13 Posters 17.4k Views 13 Watching
    • JQLJ Offline
      JQL
      "Sophie got Beamed up and looks alright"
      LOL a bit flat if you ask me...
      www.casca.pt
      Visit us on facebook!
      • GarethG Offline
        Gareth
        All is good now....
        the "**C:\Users<YourUserName>\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins**" worked a treat
        Thank you...!!
        ...life should be easier than this 😆
        • Mistro11M Offline
          Mistro11
          Turns out my issue is similar to someone else who posted it over at KT forums
          http://www.kerkythea.net/forum/viewtopic.php?f=10%26amp;t=10502
          I even installed my free version 8 on the W7 machine and it's the same issue, so not a 2014 specific thing. The plugin works fine on my XP machine but not working in W7. It seems I have some kind of permissions configuration thing going on but at least I can create the xml file and open seperately in KT. Any ideas?
          i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
          Structural Integrity is Not Just Physical...It's in the Design and Purpose
            tomasz
            Have you extracted 'su2kt' & su2kt.rb files to the User folder?
            If so, the files in the folder don't require admin permission.
            Delete kt_path.txt if the 'su2kt' folder. This should help.
            Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
            • X Offline
              xlu73
              Bonjour j'essaie d'installer kerkythea pour sketchup pro 2014 mais sketchup ne reconnait pas les plugins de kerky. Cela fonctionnait pourtant très bien avec les versions antérieures de SU. Quelqu'un aurait-il une solution?
              D'vance merci,
              Xavier.
              • FrederikF Offline
                Frederik
                Comme il s'agit d'une communauté internationale et comme vous pouvez voir la plupart sont écrites en anglais, je vous conseille de bien vouloir écrire en anglais...
                D'vance merci
                Cheers
                Kim Frederik
                  LUSO1708
                  How do I install the plugin to export from sketchup 2014 to kerkythea on mac?
                  • JQLJ Offline
                    JQL
                    For Mac you have two options on kerkythea site, in the page where you download the plugin.
                    (www.kerkythea.net)
                    Open the Zip file and there you have a text file with more instructions.
                    You can also use the same trick I recommended above, and change .zip to .rbz then go to Sketchup and in the Sketchup menu > Preferences > Extensions > install extension and choose the new rbz file.
                    www.casca.pt
                      Mario
                      just copy the su2kt.rb and su2kt folder, to the C:\Program Files (x86)\SketchUp\SketchUp 2014\ShippedExtensions, and it works fine.
                        Kamkoom
                        Hi there,
                        I also have problems installing the plugin, after I read here there is a different way to do it for SU2014, so I tried it this way.
                        C:\Users<YourUserName>\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins\
                        But apparently my computer doesn't have AppData, it has Roaming but that file is empty.
                        Can someone help me with this problem?
                        Is there an other way?
                        Also I have windows 8, I don't know if that change things.
                        I really hope someone can help me because I really need it, it would be sad that I just upgraded my SU and won't be able to use KT.
                          Jim
                          @tomasz said:
                          It all works here. It works even better, because you don't need administrator rights anymore.
                          Not quite. The start.kst file is still being created in the Program Files folder which does require admin permissions.
                            scifiwarships
                            @gareth said:
                            I have changed the folder from .zip to .rbz. but I can't get the folder to show as a selection when I click 'Install Extension'.
                            All other plugins have installed successfully into SU2014 over the past day, but KT is giving me a bit of grief....!!
                            Hi mate, I have the same problem. Just to check, did you unpack the zip folder first, or does it still have the blue z on it after you changed to the .rbz extension?
                            It has to be unzipped first.
                            Best of luck!
                            • JQLJ Offline
                              JQL
                              If you turn a rbz into a zip you cant auto install from Preferences > Extensions. If you want to do that, you have to have a rbz file.
                              You just turn it into a zip if you know the folder where the plugins are located and you want to drag the plugin files to the folder. That is not standard practice and you must know what you're doing.
                              So, general rule, don't install plugins from ZIP.
                              www.casca.pt
                              • 2 / 2
