    Layout won't update the model reference
    layout
    2 Posts 2 Posters 2.3k Views 2 Watching
    • zain01Z Offline
      zain01
      Hi everyone. Can someone tell me why layout sometimes doesn't update the model reference and yes i have saved my sketchup changes.
      Thanks in advance.
        It would be easier to give you a definitive answer if the LO file was available but we'll try without it and do the best we can. The typical reason is that the viewport has been modified from the original SketchUp scene. This happens with you open the viewport and orbit or zoom the view of the model. You can tell the viewport has been modified by the addition of [Modified] in the scene name displayed in the SketchUp inspector when the viewport is selected. Select the unmodified version of the scene from the list and it should update. Best practice is to avoid creating modified scenes in LO.
        Another possibility is that your SU file is not linked to the LO file any longer. You can determine that under File>Document SetUp.
