    IMPORTING 3DS FILE INTO SKETCHUP
    25 Posts 2 Posters 4.0k Views 2 Watching
      7an23
      ok well i did as u said and i unchecked everything and checked them again one by one to see where the slowness is coming from... and finally i realised that the amount of doors i have and people is crazy they really made it extreme slow for me, but the design alone without the doors and people still slow.. so i imported the 3ds file into rhino, and its just crazy every line is meshed, so im gonna go back to sketch up and will follow these steps in the link u sent.. u still havent told me what the purge is?
      • olisheaO
        olishea
        πŸ˜† Just read the purge link I shared. Purging removes unused components, materials etc from your model. why are you importing into rhino, I don't get it?
        You must delete geometry, not just hide it. If you're hiding objects they are still in your model. If you delete components one by one and purge, you'll find whatever is slowing down your model.
        oli
          7an23
          i just did the steps, clicked on 'purge unused' but nothing happened? how do i know whats changed?
            7an23
            well im only importing it to rhino because i want to hatch some sections for my design and i dont know to to get a scaled print from sketchup :S
            • olisheaO
              olishea
              still slow? can you even post a few screenshots of your model? anything will help!
              oli
                7an23
                [img]C:\Users\Hanan_22\Desktop\image%20one.MHT[/img]
                [img]C:\Users\Hanan_22\Desktop\image%20two.MHT[/img]
                sorry but these are the two images i could get
                  7an23
                  these images open in Explorer only :S
                  • olisheaO
                    olishea
                    just upload it direct to the forum. click upload attachment when you are replying. you may need to resize the images if it fails.
                    oli
                      7an23
                      the same images i sent you?
                      • olisheaO
                        olishea
                        I am close to giving up here! πŸ˜†
                        oli
                          7an23
                          these are the images... nooo dont give uppp
                            7an23
                            did u give up? 😞
                            • olisheaO
                              olishea
                              bed time, others will be along to help I'm sure and i'll help out tomorrow too.
                              are all your chairs and imported furniture components? Have you tried deleting parts of your model to see what's causing the problem? This is the only way to determine what's causing the stickiness. It is quite a large model, but no reason why it can't run smoothly with proper use of components and layering.
                              oli
                                7an23
                                sorry for keeping you.... like i said im really bad at sketchup so im not sure what the chairs are... all i did was download them from warehouse, i think that is components...
                                but thank u so much u did help alot.... and please dont forget meee,.. i do really need your help tomorrow 😞,.. my submission is in three days, freaking out.. anyways good night πŸ˜„
                                • olisheaO
                                  olishea
                                  After looking at your images, I would start by removing all the imported components like the chairs etc. I have said a few times imported components can be VERY heavy poly. In your theatre there are loads of imported chairs that could be slowing things down. I'm not saying that's the only problem but start there.
                                  Have you actually tried deleting parts of your model, then PURGING it, then seeing if it's any quicker? This is the only way to see what is causing the problem.
                                  If your project is due in a couple of days and you have an unworkable model, then keep it simple to get your point across.
                                  A component is like a block in CAD. You can copy and past a component a hundred times and it doesn't increase file size. If you don't use components, the file size can increase dramatically. If you make a change to one component, it will affect all the same components.
                                  oli
                                    7an23
                                    hello sorry for the late reply, i have deleted as much components as i can and i also purged it, it moves fine in wireframe but once i shade it it slows down
                                      7an23
                                      im really worried i dont know what to do anymore.. this is so difficult, more than i though it would be
                                      • olisheaO
                                        olishea
                                        Upload model to dropbox or box.com and share a link please. See if we can help you out before your deadline.
                                        Any "complex" model slows down when shaded. If it's unreasonably slow then you'll have to do something about it. I almost always navigate a complex model in monochrome mode.
                                        It's because SU is a total arse and doesn't like anything "complex". How dare you model anything more than a cube?! πŸ˜† πŸ˜† πŸ˜†
                                        Upload model and I'll have a look.
                                        oli
