Invisible layer plug-in
I used to have a plug in that gave me the ability to add an invisible layer. Now with upgrading to sketchup 2014 pro I don't see this plug in available. If my model had tons of scenes and tons of layers, then all of a sudden I need to add another layer, the layer is visible in all the scenes and I have to go to each scene and manually delete the layer so it doesn't show. I have checked the current layers plug ins in the extension warehouse and they don't have anything that resembles this. Is there something else I can do to accomplish this?
Where did you look for this plugin?
Maybe this would do the trick.
Make sure you are installing fresh copies of plugins and not just dragging them over from a previous version.
Thanks for that Dave. That looks like it would do the trick. Do I have to manually put this into sketchup? I can't see where to do that at. Sorry for my ignorance.
You can either download the file with the red Download button and then use Install Extension under Preferences>Extensions to install it or, better yet, install the Sketchucation Plugin Store plugin from the link at the top of the this page and let it automatically install plugins for you.
BTW, please complete your profile with OS and SU version. It'll be helpful in the future.
