    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 927.4k Views 172 Watching
      Anton_S
      @mister k said:
      Actually by stiffness I mean defining how much entities will resist intersection, not sure what the technical term is for that. So you could make items act as if they were soft/stiff without demand for full on deformation.
      Body.#set_softness(0.01 - 1.0)
      A softness of 0.0 makes body act more like a metal ball i.e the momentum is transferred pretty well.
      A softness of 1.0 makes body act more like a soft ball i.e the momentum is barely transferred to the colliding body.
      Is that what you were asking?
      @mister k said:
      And by collision accuracy I meant just the extent of the calculation, so entities defined as less important would require the lowest amount of processing.
      Newton has a feature called auto-sleep. In interactive solver model, the bodies that don't need any further processing go to sleep mode.
      You may also freeze the body or enable/disable the body, which temporarily adds/removes body to/from simulation processing.
      As mentioned of interactive solver, Newton has exact and interactive solver models. Interactive works much faster, but less accurate.
      Exact works slower, but more accurate.
      However, you can't assign exact/interactive solver model to a particular body. The solver model affects the calculation of all bodies at once.
      I think for gaming purposes it would be best to enable/disable body. Newton has the islands feature as well. I'm not sure what it does though. Maybe it does exactly what your asking: enable/disable particular areas of simulations processing.
      Meantime the solver model can be controlled via Menu -> Plugins -> MSPhysics -> Simulation -> Solve Model -> [Option]
      @mister k said:
      Also did you consider crossing over your scripting part with already available Ruby scripting plugins? It seems like something that would save plenty of time with that interface, although I don't know which specific plugin would work best, perhaps some of the other forum goers could pitch in with that.
      Newton has custom joints written in C++. All I have to do is convert it to Ruby and add some ticks to make it more Ruby.
      I am aiming to use Ruby 3D sounds library, though. I'm not planning to write my own lol.
      • JonFarJ Offline
        JonFar
        wonderfull! thank you!
        i was just looking for something like SketchyPhysics that worked with Sketchup 2014
        i have just one question: does the speed of objects falling/moving depend on CPU/GPU power?
        cause if i remember correctly, in SketchyPhysics objects seemed to fall/move faster
        keep up the good work, cant wait for the final version
          Anton_S
          While running simulation go to (Menu) Plugins -> MSPhysics -> Simulation -> Speed -> Double
          This will increase speed by a factor of two (Note that accuracy will become very bad).
            livebluetooth
            Dear Anton,
            I really appreciate your work πŸ‘ and also thanks to Chris Phillips for his idea πŸ‘ .
            Sorry to say but Could you please make a starting tutorial.
            Requesting you that please do not keep dependency on other plugin.
            I have gone through the website http://www.simfonia.fr/our-products/
            for "Simfonia". It is commercial plugin not Free
            I have not seen any joints. I think you are releasing in coming version.
            Could you please add some solid,liquid,gas state and their basic properties.
            Need control panel screen to see all the dynamics data. Ability to draw the graphs and controls on it.
            While Simulation phase need dynamically to do Orbit,Pan,Zoom and bla bla bla....
            I hope you are very smart and intelligent.
            God Bless You. πŸ‘
            Have a Nice day ahead. β˜€
            • pcberdwinP Offline
              pcberdwin
              This is awesome but I was wondering if there is a way to save the simulation; when I use anything else like the select tool the simulation resets.
                Anton_S
                When I release version 1.0.0
                I'll try create an installer that would install two plugins at once πŸ˜›
                Yup, you can expect joints in version 0.2.0
                You can control densities of bodies via the MSPhysics API, but I haven't added the air density feature yet. Somethig to add to the list... As far as having waters, that's something very hard to make. That requires viscosity, bubbles, and stuff. Maybe in the future versions, who knows? πŸ˜†
                That's not something you can expect in version 1.0.0, but there is a high chance in later versions, with the help of developers...
                You can already use the orbit/pan/zoom while simulation is running, however I made it to pause when you suspend and play when resume.
                  Anton_S
                  Saving with simulation running is not a good thing. There will be a record animation feature, though, similar to SketchyPhysics one.
                    Mister K
                    A softness of 0.0 makes body act more like a metal ball i.e the momentum is transferred pretty well. A softness of 1.0 makes body act more like a soft ball i.e the momentum is barely transferred to the colliding body.
                    Yes that would do it.
                    Is there also no way to stop or exclude a certain group once enough passes are done, say on "Interactive: 8 passes" does the physics engine have functions that could exclude entities just after 1 or 2 passes?
                    Or perhaps an even cruder method of running a separate simulation with every individual group, each with different settings, would that work or add to much initializing time?
                    Actually on that scripting thing I meant script editors specifically, if you considered integrating with one that already has all the code editing features so you don't have to start from scratch.
                      Anton_S
                      That's quite an idea, though it will require me to rewrite the whole API πŸ˜† Maybe you would be able to to control body via script, i.e. apply custom forces and freeze/unfreeze bodies.
                      Dialog in progress!
                        Mister K
                        There is no need to do anything crazy especially when there are all the more important parts to do, I'm just asking about the general possibilities of the engine you might have come across.
                        And on that note, to what extent can joints be put together now?
                        Could you combine several joints into one part thing? Because in SP we always had this problem that each movement axis needed an extra body part.
                        And can they be made soft/stiff as well? In SP things do like to stretch and bend out of control, and their distance/angle limits mean very little when there is force applied to the bodies.
                          Anton_S
                          Newton allows you to create custom joints. First version will have all joints similar to SP, next versions could become bloody and complicated with joints. πŸ‘Ώ
                          Joints in Newton are constraints. Its impossible to make them 100% stiff, but the softness/stiffness can be controlled. From current observations, joints are more stiff with the solver model set to exact, but pretty soft and unstable when the solver is passive. I'm aware there is an error somewhere in the constraint behavior, but meanwhile I can't clarify you on distinctive stuff. Let's continue discussion on joint flexibility once I'm done integrating them to MSPhysics.
                          • majidM Offline
                            majid
                            πŸ‘ I have an eye on this topic, seems promising
                              Mister K
                              OK, just a couple tiny things to think on as you are implementing the joints.
                              Can you easily swap out or add joints while simulating? Say you wanted a wheel/arm to lock in place after it moved a certain distance at that point you could attach a "fixed" joint that would lock everything in place (in SP anyway), is that doable or can perhaps even be done better with something else?
                              Another problem in SP was "weight"(size x density) of an object would determine joint stiffness as well, could that be manipulated when calculating joints without disrupting the entire models weight balance?
                                Anton_S
                                Yes, each joint is a class. Creating/removing joints will be easy during simulation, @my_jnt = Hinge.new(pos, pin_dir, parent, child, min = 0, max = 0, friction = 0)
                                You will be able to do @my_jnt.#connect, or @my_jnt.#disconect.
                                To get all joints within the body you would write Body.#get_joints. To get all joints the body is connected to, you would write Body.#get_connected_joints.
                                It will be quite easy to use the joint interface.
                                I'll look in to it
                                  Sofia Oliveira
                                  Hi! I am a student of electrotechnical engineering and i'm doing a project. I need a little help! How i get values from serial port to MSPhysics?
                                    Anton_S
                                    https://googledrive.com/host/0B3qg8f4WrNdHWktZLXN5T2d6Tms/blink.gif
                                    https://googledrive.com/host/0B3qg8f4WrNdHWktZLXN5T2d6Tms/laugh.gif
                                      Would help to be a bit more specific, like what data are you getting from the serial port and what do you want to use that data with in MSPhysics?
                                        Sofia Oliveira
                                        Data from an accelerometer to move an object in MSPhysics.
                                          Anton_S
                                          I assume your speaking of the accelerometer that returns its own acceleration along three axis, am I right?
                                          The main problem were facing now is how to get accelerometer data into SketchUp?
                                          I don't know about Macs, but on PC we use Microsoft Windows API, [Raw Input](http://msdn.microsoft.com/en-us/library/windows/desktop/ms645536(v).
                                          The next question is using this accelerator data to control velocity of the particular body in MSPhysics. Of course, accelerometer data may be used for other purposes, but I assume you want to control body velocity with it. For instance, you move accelerometer to the right, the body moves to right as well.
                                          I'm sorry to say, but current version (0.1.0) of MSPhysics doesn't have a scripting feature, so we'll write the code for SketchyPhysics. I assume you have sketchy physics 3.2 installed on SketchUp 7 or on SketchUp 8.
                                          Before I attempt to write a script, I want you to verify what kind of accelerometer you're using. Perhaps a url to where you bought it would be helpful. ➑
                                            Sofia Oliveira
                                            My accelerometer is a MPU9150 which is actually an IMU. My idea is, having a board with the MPU9150 and a Bluetooth Low Energy module (CC5541) that sends the values to a USB/BLE dongle (CC2540). The dongle is recognized by Windows as a Serial Port (COMxx). We master the Bluetooth component but we can’t get the accelerometer data into Sketchcup.
                                            We’ve made a DLL in C# that is able to get data from the IMU (via Bluetooth) and compute a x,y,z position from both accelerometer and gyroscope data. We would like to use this x,y,z coordinates to move a shape inside Sketchcup.
                                            My goal is that Sketchup, with these IMU values, make a movement on an object.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 46
                                            • 47
                                            • 13 / 47
