[Plugin] TIG-scale2surfacearea
Copyright 2014 (c) TIG
All Rights Reserved.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
Usage:
Plugins > TIG-scale2surfacearea
Context-menu > TIG-scale2surfacearea [with a suitable preselection]
Action:
Preselect a Solid Group/Component-Instance Object.
Activate the Tool.
The Object is Scaled to give the Surface Area entered in the dialog,
you also specify the Units and the Scaling's Anchor-Point
[Object's Bounds-Center or Insertion-Point].
You can also specify its 'Mode' - to work on the Original or a Copy.
Objects are made unique.
The Scaling is one step undoable.
The dialog displays the Object's Surface Area in current Units.
The last used Units, Anchor-Point & Mode are remembered during that session.
Version:
1.0 20140526 First issue.
Download the latest version from the SketchUcation PluginStore http://sketchucation.com/pluginstore?pln=Scale2surfacearea or AutoInstall it from within SketchUp itself using the 'SketchUcation Plugin Store' tool's dialog... http://sketchucation.com/resources/pluginstore?pln=SketchUcationTools
Awesome, thanks so much TIG.
This plugin is perfect for reducing surface area of a model for 3D printing in ceramic.
With i.materialise 3D printing service, ceramic is charged by surface area so this plugin will be useful to anyone 3D printing in ceramic and looking to reduce costs.
Thanks again, this is above and beyond what I expected.
