    Nesting DC components - how many levels?
    Scheduled Pinned Locked Moved Dynamic Components
    2 Posts 2 Posters 1.3k Views 2 Watching
    • T
      toddbg
      Hi -
      How many levels can you nest dynamic components?
      For my fence model I have a horizontal lattice piece that is DC for scaling it's width (with dado) it is made up of left end - dado segment - right end.
      there is a vertical member that I want to place against 15 or so of the horizontal members.
      I then want to be able to make that set of components into a component that replicates.
      Anyway, there is also some framing that I need to dynamically move position based on the overall width of the base lattice.
      So - how many layers can I nest and still reference?
      is it able to be run up and down the nested stack?
        Jim
        You can only reference attributes a distance of one component away. Parent -> Child, Child -> Parent, Sibling -> Sibling.
        So if you need deeply nested DC's then you need to repeat the attribute at each level.
