    Playing Around.
    30 Posts 6 Posters 5.6k Views 6 Watching
    • olisheaO Offline
      olishea
      A 3D print project.
      http://i654.photobucket.com/albums/uu269/olishea/3_zps0ab8f1cd.jpg
      oli
      • pbacotP Offline
        Nice--how did you model the holey one?
        • olisheaO Offline
          olishea
          Not with sketchup.
          I used the orange one as a base to encrust point samples in meshlab, then mesh between them in (what seemed like) a 50 step process in an app which has no undo function! I'm trying to learn how to do this in Wings but it's a completely different way of thinking.
          Why would you make a modelling program without an undo button?!
          oli
          • Rich O BrienR Online
            Life has no undo. They might have mimicked that?
            • olisheaO Offline
              olishea
              Did you see the video on how to undo in meshlab?
              I think I've cracked this in Wings, with some help from the plugin developer of course! πŸ˜„
              oli
              • olisheaO Offline
                olishea
                Getting some cool/strange results! Quite refreshing to not be using SU actually.
                http://i654.photobucket.com/albums/uu269/olishea/ScreenShot2014-05-20at204356_zps8aa53b9c.png
                http://i654.photobucket.com/albums/uu269/olishea/ScreenShot2014-05-20at203420_zps05011e54.png
                http://i654.photobucket.com/albums/uu269/olishea/ScreenShot2014-05-20at204455_zps9babb613.png
                oli
                • pbacotP Offline
                  Nice...that's wings?
                  • olisheaO Offline
                    olishea
                    yeah, its hard to get your head around at first but great modelling app.
                    I wish sketchup quads weren't actually triangles, it's so frustrating.
                    mods: can you put this in the WIP section please. cheers.
                    oli
                    • tademaT Offline
                      tadema
                      Duck Shoes πŸ˜„
                      John
                      • olisheaO Offline
                        olishea
                        hahahaha that works really well! you even made a reflection of them in the ice haha πŸ‘
                        oli
                          d12dozr
                          @olishea said:
                          Getting some better voronoi objects, would be cool printing these in the rubber-like material.
                          You can! πŸ˜„
                          Shapeways: https://www.shapeways.com/materials/elasto-plastic?li=nav
                          i.materialise: http://i.materialise.com/materials/rubber-like
                          Check out the video to see how it flexes.
                          http://goo.gl/f7ooYh
                          • olisheaO Offline
                            olishea
                            Whoop! What a fun and playful material!
                            The reason I mention rubber is because it's non porous and you can print much thinner wall thicknesses than ceramic for example. But because my model is a stand to hold something, maybe rubber is not a good idea if it's quite floppy or too flexible. Only samples will tell.
                            Can you recommend a strong and non porous material other than ceramic? MUST be non porous.
                            Finally got a reply from the 3D printers about bulk orders, I'll see if it's possible or not to mass produce.
                            oli
                            • pbacotP Offline
                              Are you going into business? !!
                              (The latest results show a less defined depression in the stand, if that has to be a tight fit.)
                              • olisheaO Offline
                                olishea
                                Hopefully yes! I have the biggest UK distributor of electronic cigarettes on board, so I must make it work. I need to halve the manufacture costs so that's why I'm looking into these shapes. I played a prank, posting renders on their forum of imaginary products and loads of people asked where they could buy them haha so I got talking with the shop owner.
                                No it can not be a tight fit, as not to rub on people's shiny and expensive gadgets, it's supposed to be a relatively loose fit. Thanks for looking.
                                oli
                                  d12dozr
                                  I don't think you're going to find any other decent rubber material that can be 3D printed.
                                  What you might look into for that quantity is short-run injection molding, where you can make the parts in plastic, hard rubber, or a few other materials. They'll have to make a mold, which is pretty pricey, but then the cost-per-part is waaaay cheaper than 3D printing or milling.
                                  • olisheaO Offline
                                    olishea
                                    Yeah that's an option I was looking into. I just don't want the object to feel too cheap if it's made in plastic. I'll look into what materials protolabs offer for injection moulding, hopefully something funky. I hope 3D printing will be OK but if it's prohibitively expensive, I'll have to change material and manufacturing process anyway.
                                    oli
                                      d12dozr
                                      One thing I really want to look into is glass. How sweet would some funky CAD generated designs look like in glass?? πŸ˜„
                                      I know they can 3D print a model, then make a mold around that and cast glass, but once again for larger models the 3D printing becomes cost prohibitive.
                                      Must...find...cheap, large scale 3D printer...
                                      • olisheaO Offline
                                        olishea
                                        I think it's called China. πŸ˜†
                                        Yeah glass idea is great! Can it be injection moulded any way? Or just cast?
                                        Yeah, no wonder most 3D printed designs are delicate, thin meshes or voronoi structures. If they aren't they cost hundreds, even thousands for a tiny object! The cheapest material is ceramic, but it's limited by wall thickness. So annoying!! To put it into perspective a model just less than 100 cm cubed costs nearly $40 in ceramic. That's actually quite a small object too! You almost have to print webbed/voronoi/trussed models or the cost makes things impossible.
                                        oli
                                          d12dozr
                                          China...no kidding πŸ˜„
                                          Glass can be molded, that's how glass bottles are made. I don't know much beyond what I've seen in "How it's made" Youtube videos though.
                                          • olisheaO Offline
                                            olishea
                                            Yeah I think that may be over ambitious! Gotta love How It's Made!
                                            Will post some more renders soon, I've all but ditched the above model. It needs some refining anyway.
                                            oli
