    Reading and drawing textures
    22 Posts 7 Posters 1.9k Views 7 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @marc477 said:
      How am I supposed to access a texture data ? I'd like to get the value of a pixel in the texture linked to a specific material, but there is no data property in the texture class.
      This is not part of the API currently. You would need to use external 3rd party tools, such as ImageMajik.
      I'm not here much anymore.
      • tt_suT Offline
        tt_su
        @marc477 said:
        Hi, I am new to the community and I just started a project.
        Welcome! πŸ˜„
        That's correct - the Ruby API is missing such feature. I'll see if we don't already have a feature request for this and file one if we don't. It'd be a nice feature.
        @marc477 said:
        Also, I'd like to draw a 2D texture, I saw the draw2d function but it seems to draw solid colors only.
        Another limitation I'm afraid, there's currently no way to draw bitmaps to the viewport. Would be a great addition.
          Marc477
          First, thank for all the fast answers.
          @dan rathbun said:
          The OpenGL draw functions are for use during custom Tools only, and they draw on the viewport, not in the model.
          Sorry, maybe my explanation was confusing, but what I want to do IS drawing in the viewport via a tool. I don't want to change the model and I don't want to change the .skp file.
          And how can I get texture's data loaded in SketchUp memory with an external tool ?
          Do you mean that I should write every texture with the TextureWriter and then load them with an external tool ?
          Thank you
            Dan Rathbun
            The whole point of a Tool, is to allow the user to change the model. Otherwise the tool is pointless.
            But perhaps you just wish to show some information on the viewport. Yes you can do this when your custom tool is active, but the viewport will be reset when the user actives any other tool (most likely.)
              Dan Rathbun
              I never said you could do this.
              OK.. sorry the term "tool" is not correct (in the SketchUp sense of a "tool",) ... ImageMajik is an image manipulation utility program. I believe it comes as a command line executable, but may also be available as a dll.
              You said you wanted to read a certain pixels value. An image utility "like" ImageMajik should be able to do this. The utility would temporarily load the texture file into it's own memory space.
              You could also use platform dependent libraries. Windows GDI+ etc., and make calls to them via Win32API.
              If your on Mac, then I do not know. One of the Mac guys can chime in.
              • tt_suT Offline
                tt_su
                I'm confused - when you say "external tool" - you mean a custom Ruby Tool? Or some third party software?
                And "load in memory" you mean for reading the bitmap data? ... I guess you want the bitmap data - since you talked about this earlier.
                With SketchUp 2014 you now have the standard Ruby library and the gem system - you might be able to find some ruby gem you can install and use.
                  Dan Rathbun
                  Thomas he was responding to my use of "external tool", and I meant external utility library.
                  ImageMagick DOES have a gem, and is available for both PC and Mac.
                  Download the Ruby RMagick Gem: http://rubyforge.org/frs/?group_id=12%26amp;release_id=42049
                  (Use the MajikCore C API library.)
                  The ImageMagick site: http://www.imagemagick.org/
                  With 4 choices to use the libraries under Ruby: http://www.imagemagick.org/script/api.php#ruby
                  Here's the doc page on the view class.
                  http://studio.imagemagick.org/RMagick/doc/struct.html#view
                  (you can also use the Image.view instance method.
                  See: http://studio.imagemagick.org/RMagick/doc/image3.html#view
                  You need to install the ImageMagick libraries separately for the gem.
                  I have not gotten the gem to install to my system Ruby install... yet.
                  I get an errors.
                    Marc477
                    Yes sorry I meant "external third party library" and yes I want to read bitmap data.
                    Ok so there is absolutely no way to read bitmap data of loaded textures in Sketchup!?
                    Does that mean I need to double memory usage by reloading textures with an external library (probably OpenCv since I am working with a C extension).
                      Dan Rathbun
                      You can also use the ImageMagick libraries. (It is Open Source.) .. or maybe GIMP libraries ?
                      OR... FreeImage which SketchUp uses, and may already be loaded.
                      http://freeimage.sourceforge.net/
                      • tt_suT Offline
                        tt_su
                        Correct. I think we have a feature request to access the DIB data - but right now it's not possible.
                          Aerilius
                          The Ruby gem creates a wrapper around the almost complete ImageMagick API. For use with SketchUp, the major (and time&resource consuming) task is to export the texture image to a file in a temporary location, read it again and clean it up when not needed anymore. To improve performance, you would even need a caching mechanism.
                          All this is not provided by the Ruby gem.
                          For long image manipulations you would also want to run ImageMagick asynchronously, including the Ruby code that you run afterwards. Since I usually use only one or two ImageMagick commands (not the whole API) I once made a library that does the caching and asynchronous stuff.
                          Still, calling an external program is not ideal if you want to do a very interactive tool (see here). Then you would rather nudge Thomthom to include some more pixel reading/manipulation methods to the API. They could already be designing for the next version.
                            Dan Rathbun
                            @Andreas: I got an error, trying to compile the latest RMagick gem, under Windows, using the latest 32bit Ruby Devkit, for Ruby 2.0, against the latest 32bit ImageMagick (installed in "C:/ImageMagick".)
                            Were you able to compile such a so file ? If so can ya share it ?
                              Dan Rathbun
                              @tt: For a Ruby C extension, is it possible to get a handle on the FreeImage library that SketchUp has loaded ?
                              Or.. is it better to just re-load it when needed, and free it when done ?
                              • N Offline
                                nick9111
                                Hi, I am new to the community and also have a thing I don't understand how it should be done. For example, I can get filename of texture which is saved inside .skp file using
                                Sketchup.active_model.materials[0].texture.filename
                                Is there a way to rename it? (and keep reference of associated material to it)
                                  Dan Rathbun
                                  The texture is a property of the Material.
                                  Save the material's size (if width and height differ,) so you can restore that.
                                  Then re-assign the material's texture using:
                                  matl.texture="new/path/to/renamed/imagefile"
                                  Lastly restore the size needed.
                                  • TIGT Online
                                    I've answered this in your parallel thread http://sketchucation.com/forums/viewtopic.php?p=524826#p524826
                                      Marc477
                                      Thank you all, now I know how to do the first step (Reading texture data) but now I still wonder how to do the second step: drawing textures.
                                      As discussed above it doesn't seem to be possible to draw them in the viewport so I tought I could create a new window and display an image in it. I found that there is a WebDialog class that could be useful to create the new window, but now does anyone know how I can draw an image in those dialogs? I would like to avoid reloading the texture from Hard Drive everytime I refresh the image (since the image will be edited).
                                      I could load the texture only one time from the Hard Drive using ImageMajik (Thanks Dan), then update the "in memory" buffer directly and display it in the WebDialog. Is it possible to do that ? How do I draw in a web dialog an image loaded with ImageMajik ?
                                      • fredo6F Offline
                                        Not sure I understand what you mean by reading textures, but you can at least extract them from Sketchup and show them as images in a web dialog.
                                        TIG's method is the right one to go.
                                        Here is a screenshot of my plugin ReportLabelArea
                                          Dan Rathbun
                                          I do not think anyone has ever done it.
                                          The HTML5 Canvas element will not work well on PC yet because SketchUp uses the MSIE WebBrowser control for WebDialogs. Microsoft is lagging behind in their IE support of the specification.
                                          You CAN use the RMagick gem to draw, and save the edits to disk, and MSIE knows how to natively render image file formats, but you'll need to refresh the web dialog, to re-render the imagefile. (or have a html IMG element within a HTML file.)
                                          See the doc: http://studio.imagemagick.org/RMagick/doc/
                                          Also note there IS a RVG class that is based upon SVG.
                                            Dan Rathbun
                                            You can test by loading the HTML5 Bejeweled game into a WebDialog.
                                            It most likely will not run under XP. But runs fine under Win7 with MSIE v11 installed.
                                            Bejeweled.rb
