    KERKETHEA PLLUGGIN
    12 Posts 4 Posters 687 Views 4 Watching
      How about some actual details? You downloaded the plugin but what did you do with it after that? Where did you download it from?
        @Dave
        Does it work for the 2014?
        PS I have seen your video! β˜€ (you say inside that you use it but not precise the version)
          Pilou, the SU2KT plugin does work fine with SU2014. These were all rendered in Kerkythea after being drawn in SU2014 and exported via SU2KT. The plugin is compatible with SU2014 without needing any updates.
          https://farm8.staticflickr.com/7376/14101223081_26fa81e873_z.jpg
          https://farm8.staticflickr.com/7393/13526644674_3f5a613fe6_z.jpg
          https://farm6.staticflickr.com/5161/13926144002_3c1f71ab26_z.jpg
          https://farm8.staticflickr.com/7402/12586670093_546d8c8415_z.jpg
            Many thx for the infos! 😎
            • N Offline
              notareal
              @serrot said:
              I downloaded the Kerkethea pluggin for Sketchup but I am not able to find it in my files to activate it...HELP !!!
              OS?
              Plugin version?
              SU version?
              Did you extracted the plugin to a correct folder?
              from su2kt_Install.txt (included in su2kt_XX.zip http://www.kerkythea.net/cms/index.php/downloads/software)
              1.Please copy su2kt.rb and su2kt folder into Sketchup\Plugings
              	>> Sketchup\Plugins\su2kt.rb
              	>> Sketchup\Plugins\su2kt\
              Overwrite all older files.
              On PC the default folder is;
              	C;\Program Files\Google\Google Sketchup ... \Plugins
              On MAC the default folder is;
              	Macintosh HD/Library/Application Support/Google Sketchup ...... /Sketchup/plugins
              If you a windows user, it's best to give your account a modify permission on "C:\Program Files (x86)\Kerkythea Rendering System" and also on SU plugins -folder.
              Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                serrot
                I downloaded the plug in from the Kerkethea website onto my pc with windows 8
                  And that's all you did? Simply downloading the ZIP file isn't enough. You have to actually install it. Can you locate where you saved the ZIP file? Have you ever installed a plugin before?
                    And "unzip" a zip file ?
                      serrot
                      no first time and I have never unzipped a file
                        OK. I made a .rbz version of the SU2KT plugin. Download it and keep track of where it gets saved. If you are still using SketchUp 8, navigate to Program Files (X86)/Google/Google SketchUp 8/Plugins. Right click on the Plugins folder and choose Properties. Then click on the Security tab. Click Edit. Select your log in user name and in the lower pane set all the tick boxes to Allow. Then click Ok and OK again. Close the window.
                        Next, open SketchUp. Go to the Window menu and click on Preferences>Extensions. Click the Install Extension button, go to where you saved the file and choose it. Click Open and the affirmative answer when asked if you want to allow it to install. Finish installing and close the Preferences window by clicking OK.
                        Close SketchUp and reopen it. Look under View>Toolbars for the SU2Kerkythea toolbar and activate it.
                        SU2KT_3_17+.rbz
                          serrot
                          Thank you
