    Angular precision glitch with SU Mac
    6 Posts 4 Posters 1.9k Views 4 Watching
    • Jean LemireJ
      Jean Lemire
      Hi folks.
      This glitch is present for both SU 2013 and SU 2014. SU 8 is OK.
      Try this:
      1 - Select Window Menu --> Model Info --> Units
      2 - In angle unit, my precision is set to 0.0 by default. Try setting it to 0.000. It is still stating 0.0.
      3 - Try setting it to 0. Now you have two checkmarks beside both 0 and 0.0.
      4 - Try 0.00. Now you have two checkmarks beside 0.0 and 0.00.
      5 - Try setting it to 0.000. Now you have two checkmarks beside 0.0 and 0.000.
      6 - Try setting it back to 0.0. Now you have only one checkmark beside 0.0.
      7 - Try setting it at 0.000. everything is now OK.
      In step 2 above, if you choose 0.00 instead of 0.00 you will see 0.00 but you now have two checkmarks, one beside 0.0 and one beside 0.00.
      A bit weird.
      The procedure to reset it to a correct behavior is to first choose 0.0 even if it is already selected then choose whatever precision is required.
      Regards.
      Jean
        I followed your steps and made screen grabs. I'm not seeing anything unexpected.
          driven
          working as per dave here as well...
          do you have any plugins that work with angle precision?
          • Jean LemireJ
            Jean Lemire
            Hi folks.
            On SU 2014, in supplement to the plugins that come by default with the program, I have these plugins:
            • Engineering Toolbox
            • Pipe Draft
            • Guide Tools
            • SimLab PDF Exporter
            See the following screen grab to see the problem. Notice the two checkmarks.
            Regards
              I don't have any of those four plugins you listed. Have you tried disabling them and then setting Angular Precision? I wonder if one of them could be the culprit.
              • O
                otb designworks
                Everything s working fine for me, too. I am not seeing any of the issues you are see in,g Jean.
                Of your four plugins, I have Engineering Toolbox installed
                Cheers, Chuck
                OTB Designworks is on Youtube
