    Issue soapskin & bubble with osx 10.6.8
    5 Posts 2 Posters 275 Views 2 Watching
      milvus
      Hi, I can't find a way to get a working version of soapskin with snow leopard. It seems I can't download the last update without sketchup 2014 (10.7+) and the old versions I downloaded don't work anymore (timelimit finished). Am I missing something ?
      • jeff hammondJ Offline
        what version of sketchup are you using?
        you should be able to use soap skin& bubble with v8 and up
        SketchUp Extension Warehouse
        Your library of custom third-party extensions created to optimize your SketchUp workflow.
        (extensions.sketchup.com)
          just tried the verison via the EW link above in su8 on Lion.. it works fine.
          if you're using sketchup 8 or up, it should be a-ok..
          (though the install procedure is a little bit convoluted.. i can guide you through that after you tell me your sketchup version)
            milvus
            Version 8.0.14345
            It's totally weird, I tried many times to download it via warehouse and either the download button wouldn't work or it suggested me to use sketchup 2014 .. I tried it again now, and finally it worked !
            Thanks for .. well I don't know exactly but thanks !
              lol πŸ˜„
              i'm assuming you know how to get a .rbz into su8? if not.. let me know.
