    Plugin Continuity
    14 Posts 3 Posters 929 Views 3 Watching
    • BoxB Offline
      It sounds like you have something screwed up in your SU installation. I download it from the site and installed it via the preferences window and it all works fine. Including the toolbar.
      That .rb file you mention should reside in a subfolder.
      Have you used the defaults when installing SU2014 or did you make your own plugin folder?
      What is the path to the plugin folder you are using?
      • ashscottA Offline
        ashscott
        C:\Users"Username"\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
        Thanks for taking an interest - I feel like I'm going a little nuts but there must be something wrong....
        Just some stuff I do with Sketchup.
        • BoxB Offline
          Try deleting the folder called rp_keyframeanimation and the two files of the same name, one .rb the other .rbx. Then reinstall from the preferences window. Restart SU and see if it's working.
          You should then need to input your license, so make sure you have it before you delete anything.
          • ashscottA Offline
            ashscott
            It returns this Load Error:
            Error Loading File rp_keyframeanimation.rb
            Error; #<SyntaxError; C;/Users/Ash/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rp_keyframeanimation.rb;18; invalid multibyte char (UTF-8)>
            • ashscottA Offline
              ashscott
              Then works immediately when I move "load_keyframeanimation.rb" out of its subfolder - the toolbar icons are still absent
              • BoxB Offline
                Sorry, it's beyond my tiny mind. It works exactly the opposite for me. If I move that file into plugins I get the error and a broken toolbar.
                • ashscottA Offline
                  ashscott
                  Thanks for your effort anyway - At least I can finish my project now.
                    That error shows a Ruby2 issue.
                    If you open the .rb in Notepad++.exe is its encoding listed as "UTF8-without-BOM" ?
                    If not the change its encoding to that and save it.
                    Retry and see if the error goes, repeats or it changes - e.g. it might now point to a line number with another error ?
                    If you are lucky then the re-encoding will have fixed it, but if not then some other syntax error[s] need[s] addressing - e.g. a common one is method (arguments) - there can be no space between a method and the opening parenthesis around its arguments in Ruby2, so it's method(arguments) - the previous Ruby warned about it, but still loaded the code, but now it simply breaks !
                    • ashscottA Offline
                      ashscott
                      It won't save as "UTF8-without-BOM" I can hit "convert to UTF8-without-BOM" or "encode with UTF8-without-BOM" and save it but when I re-open the file it is back to ANSI......
                      I can get it to encode in just UTF8 but that doesn't fix anything
                        Do you want to PM me the .rb file and I'll look at it πŸ˜•
