    Another instance of sketchup using the same network....
    10 Posts 4 Posters 2.6k Views 4 Watching
      Jorgensen
      Before I have been able to run more than one instance of Sketchup on the same machine, but not I get this error
      "another instance of sketchup using the same license is running on this network (xxx.xxx.xxx.).
      I sometimes open a new session to copy some objects to a 'clean' file.
      Can anyone confirm that it's no longer possible? or is it a local error?
      Thanks πŸ˜„
        That is strange. I regularly have two or more instances of SketchUp open at the same time on the same machine. It works just fine. I'd guess it's some sort of local thing.
          Jorgensen
          Hi Dave
          Yes it's strange. I have done so before.
          I have just found out, that I can have multiple instances of Sketchup open if I disable my internet access - strange...
          • cottyC Offline
            cotty
            Are you trying to mix different licensed versions (Make, Trial, ...)?
            my SketchUp gallery
              Jorgensen
              Hi cotty
              No - I have only one instance of sketchup installed. Sketchup 8.0 pro, Commercial, Single-User.
              • KrisidiousK Offline
                Krisidious
                I also run multiple instances... no issue.
                By: Kristoff Rand
                  Jorgensen
                  And I'm sure I have been able to run multiple instances before, but now I can't.
                  Strange πŸ˜•
                    Krisidious
                    No changes to your system or network? Are you running sketchup as administrator?
                    By: Kristoff Rand
                      Jorgensen
                      Hi Kristoff
                      I can't say that I haven't changed anything. I't been a while since I tried to have more instances....
                      But I can't figure out what kind of changes has this impact.
                        Krisidious
                        Well, Sketchup seems to think that you have two different IP addresses. Do you have peer blocker or something similar running? perhaps some firewall?
                        By: Kristoff Rand
