Help with extrusion
Hello,
is it possible to do this with one operation?
Input: 3 Lines (Top, Ground, Profile)
Output:
@lamandrion said:
Hello,
not really.. how are you going to get the ground curve drawn properly as the tranny is changing? that's the hardest part.
it's best to do it in sections. I know a few tricks to maybe speed things up for you (for things like a waterfall through a rounded hip etc) but I really wouldn't recommend trying the approach you're showing in sketchup. in rhino, you have a good chance at drawing the coping then different profiles at key depth changes but that doesn't work out too well in sketchup.
