    Help me solve a mystery
    11 Posts 7 Posters 1.0k Views 7 Watching
    • sdmitchS Offline
      sdmitch
      Using Ruby Web Console, I created a method to generate a Herringbone pattern on a selected face.
      When finished and all was working as expected, I copied the code to a plugin file. But, unlike when executed from Ruby Web Console, the code produced errors, as listed below, when executed.
      =begin
      su8 errors
      h_bone
      Error; #<NoMethodError; undefined method `explode' for nil;NilClass>
      C;\Users\Public\SketchUp\Plugins\h_bone.rb;39
      C;\Users\Public\SketchUp\Plugins\h_bone.rb;36;in `upto'
      C;\Users\Public\SketchUp\Plugins\h_bone.rb;36;in `h_bone'
      C;\Users\Public\SketchUp\Plugins\h_bone.rb;35;in `upto'
      C;\Users\Public\SketchUp\Plugins\h_bone.rb;35;in `h_bone'
      (eval);15
      su2014 errors
      h_bone
      Error; #<TypeError; reference to deleted Entities>
      C;/Users/Public/SketchUp/Plugins/h_bone.rb;38;in `add_instance'
      C;/Users/Public/SketchUp/Plugins/h_bone.rb;38;in `block (2 levels) in h_bone'
      C;/Users/Public/SketchUp/Plugins/h_bone.rb;36;in `upto'
      C;/Users/Public/SketchUp/Plugins/h_bone.rb;36;in `block in h_bone'
      C;/Users/Public/SketchUp/Plugins/h_bone.rb;35;in `upto'
      C;/Users/Public/SketchUp/Plugins/h_bone.rb;35;in `h_bone'
      <main>;in `<main>'
      -e;1;in `eval'
      nil
      =end
      Thinking that some of the code cleanup I had done had something to do with it, I pasted the code between a def and end statement in a new file, loaded and executed that. But the results were the same. So the question is, why would the exact same code executed from Ruby Web Console succeed while executed from a loaded plugin fail?
      http://sdmitch.blogspot.com/
      • sdmitchS Offline
        sdmitch
        A new clue in the mystery. If the components exist before the plugin is executed, it runs without a problem. So it is something regarding the initial creation of the components in the plugin that apparently doesn't occur when the Ruby Web Console script is executed.
          driven
          if you simply wrap it as a string [ in the .rb file with eval ] and load that, does it work?
          i.e
          eval %Q(# you original code here)
          also, if you post the code it's easier to test...
            Jim
            I would not trust my old Ruby Web Console plugin. There were name-space issues if I remember correctly.
            One simple way to write and test code in SketchUp is to use your favorite editor. Then create a menu or tool button in SketchUp to load the file you are editing. The advantge of a menu is that you can create a shortcut to reload the file. It's a simple, fast, and effective workflow.
            • sdmitchS Offline
              sdmitch
              Apparently the only mystery is why creating components "on the fly" is only partially successful at best.
              • jolranJ Offline
                jolran
                I could think of 2 things related to those errors. You are referencing face.normal in the add instance method. BUT using pushpull on the face after referencing to a variable may delete the original face/faceID or reference what you may call it.
                Also maybe using load definitions from paths might bring more succes than add ?
                  Jolran is correct.
                  When you use f.pushpull() the original face is lost.
                  So when you later try to use a reference to that face ' f' it is a 'deleted-entity' - raising an error...
                  But since your container's entities only has the one face with that normal you can re-find the face if needed - or just set a reference to the normal [say as n=f.normal] BEFORE doing the pushpull that deletes the face...
                  • sdmitchS Offline
                    sdmitch
                    In this case, I don't attempt to reference the face later. Also, if the plugin doesn't have to create the components, it ran normally.
                    I tried creating a group for each "box" then group.to_component. This was a better but still unreliable.
                    I eventually ended up just adding the "boxes" to a single group rather than making components at all. This then created another problem which was resolved in the test plugin by doing nothing more than simply moving the .add_group statement. I can't imagine why that should make a difference.
                    The good news is that all the gremlins have been eliminated and all is right with the world.
                    • Dan RathbunD Offline
                      Dan Rathbun
                      The old webconsole may have done some initializing of local varibales that your method does not have.
                      Such as:
                      model = Sketchup::active_model defns = model.definitions selset = model.selection
                      etc.
                      Look at the code for the webconsole.
                      I'm not here much anymore.
                        Dan Rathbun
                        Yes you did.. you tried to create a transform using f.normal so that method would likely return nil or raise an exception.
                        Or the add_instance method would return nil making the ci reference nil.
                        Obviously you expect a valid instance or group when you use the explode method, but the reference (that you are calling explode upon,) is referencing nil.
                        Learn to write nil tests / valid test into your code to catch these errors, ie:
                        ci.explode if ci
                          dacastror
                          Is this editor will have the same behavior?
                          404 Not Found
                          (www.alexschreyer.net)
                          the author said it was based on the Ruby Web Console
                          With your input, this post could be even better šŸ’—
